Thanks Rex for your comments,
When I first tossed out some easy ways to calculate the problem solution, the initial purpose was to keep it simple and A) Rate of flow and B) Water mass required seemed to be the best way to analyze the problem. This was done not to oversimplify, but to keep it simple yet have good solutions at hand.
Although one can use a radiator in a box as one solution, it has its own inherent problems. It is quite often better to keep things as simple as possible. Fewer parts makes for fewere nooks where problems can arise.
Mr. Tauruck, Yes, yess, yesss (my best imitation of a South African accent):
I agree with Rex for a number of reasons. Way up on the hit parade of problems with cooling systems is to carry heat away from the backside of the combustion chamber as it is an easy way to keep some control of inducing detonation (rattling the engine). That should be the driving thought process of an engine cooling system. I would encourage you to simlify the dependence on complex thermostats, but that is yet another level of system analysis.
In short (after the previous rant), I strongly support the philosophy that complex is arrogant and simple is elegant.
Best Regards to All that like this kind of stuff,
HB2
