Author Topic: Current Barometric Pressure at Bonneville?  (Read 10011 times)
Offline Esslinger Eng
    • Esslinger Engineering
« on: August 08, 2014, 10:57:51 AM »
Anyone measured the Barometric (atmospheric) pressure is at Bonneville yet this year?  I have a team up there running a Normally Aspirated Gas engine that I'll be remote tuning, and I'm curious how much lower the Baro is up there so I can get an idea of how much my tune-up will be off before I get the datalogs of each run...  Just trying to plan ahead!
Brian
*** The above information is my personal opinion and does not necessarily reflect the opinion of Esslinger Engineering, Inc. ***
Offline Texican
Re: Current Barometric Pressure at Bonneville?
« Reply #1 on: August 08, 2014, 11:14:06 AM »
30.10,  64*...http://www.wunderground.com/weather-forecast/zmw:84083.1.99999
Scroll down for "More conditions"
Offline Dynoroom
« Reply #2 on: August 08, 2014, 11:14:22 AM »
Average is 25.5 in/hg
Offline hotrod
    • Black Horse photo
« Reply #3 on: August 08, 2014, 11:22:55 AM »
You can get the local barometric pressure from the National Weather service on this page (these are corrected to sealevel pressures not station pressures so you will have to adjust for altitude)
http://www.wrh.noaa.gov/total_forecast/other_obs.php?wfo=slc&zone=UTZ005
http://www.wrh.noaa.gov/mesowest/getobext.php?wfo=slc&sid=ENV&num=48    (has chart with pressures including station pressures every 20 minutes)
Also the fuel trailer posts the actual station pressure on a board by the trailer so the team can stop by periodically and get all the relevent info like temperature, absolute pressure and humidity from them in near real time.
« Reply #4 on: August 08, 2014, 11:23:36 AM »
The ERC fuel truck will have that data or try this: http://airdensityonline.com/
Offline Robert Rampton
« Reply #5 on: August 08, 2014, 11:40:04 AM »
Interesting.  This was also a concern to the first salt racers 100 years ago.
Happily afflicted with salt fever since 1988.
« Reply #6 on: August 08, 2014, 12:15:15 PM »
A better gauge is the adjusted altitude information given on your timing slip.  Pressure flies all over the place during the day, but we had adjusted air densities between 5800 and 7200 feet.
Offline revolutionary
« Reply #7 on: August 08, 2014, 02:12:11 PM »
Isn't it easiest just to run a short datalog and see what your client's MAP sensor says?
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
« Reply #8 on: August 08, 2014, 07:54:27 PM »
Is that chart from ERC at a previous event, or this event?
This car in particular is set-up on an TPS vs RPM fueling strategy with it's ITB's...  No MAP correction at this point.  Once I have a log, I'll have the Barometric pressure, I'm just working up a tuning strategy at this point...
Brian
Offline hotrod
    • Black Horse photo
« Reply #9 on: August 08, 2014, 09:35:20 PM »
Previous event date in the lower left column August 2011
« Reply #10 on: August 08, 2014, 10:39:29 PM »
The ERC truck is stranded about 3 miles from Lands End.
They can not move. Lands End Lynda said they are not
allowed to drive on the salt the way it is now.
Offline Harold Bettes
  • Firebase High Country
« Reply #11 on: August 08, 2014, 10:57:37 PM »
Howdy to All That Are Interested in This Stuff,
Some easy links for station pressure (local barometric pressure) and other atmospheric data:
http://airdensityonline.com/results/?trackname=Bonneville%20Speedway
http://www.wrh.noaa.gov/zoa/mwmap3.php?map=usa
Both are quite handy and allow you to do your own analysis of conditions. The second listing (NOAA) is for guys that are either flyers or detail types and like numbers. 8-) :-o
At least this gives you something else to do while waiting for the flats to dry out via rapid evaporation (hopefully). :roll:
Best of Luck to those waiting in Wendover or wherever you are! :wink:
Regards to All, :cheers:
HB2 :-)
Offline Saltfever
« Reply #12 on: August 09, 2014, 02:22:47 AM »
Brian since you are not in Utah the easiest, most accurate, and dependable source, is to call the FAA's AWOS* station at Wendover airport. The information is updated no less than 4x/hr and it could be as frequent as 5-10 minutes if there are rapidly changing conditions. You get temp, density altitude, pressure, visibility, etc. I just called 435/665-2521 and the number is good. The altitude of the track and the airport are within 15 ft of each other.
National weather stations and other links get their pressure data from the closest airport unless they have a special source even closer to their reporting point. However, you can not depend on their update frequency. With AWOS or ASOS you bet your life on it.  :wink:
*automatic weather observation system. (or other interpretations)
« Last Edit: August 09, 2014, 02:42:14 AM by Saltfever »
« Reply #13 on: August 11, 2014, 11:39:43 PM »
It isn't a matter of "I hope" at Wendover Airport.
Commercial flights land there daily and the info
is to be trusted.
