There is a common misconception that
any air filtration system will cost power from restriction to the airflow path into the engine. The filtration system does not need to be a power robbing solution however with most folks wanting the "quick and easy" off-the-shelf answer will probably make the wrong choice in air filtration.
The air filter system can be one way to smooth and straigten the air going into the engine. Sorta like an oil filter - surface area might be something to look at in order to decrease the potential losses. It depends on the media and the flow rate.
Don't know about you, but the care and effort put into prep of cylinder heads, seats, and cylinder walls encourages me to protect the stuff as much as possible.
Regards to All,
HB2
