Author Topic: motorcycle frame size  (Read 2637 times)
filmermikey
« on: July 28, 2014, 11:09:08 PM »
Is there a minimum diameter or thickness for a motorcycle frame? If so what is it?
Re: motorcycle frame size
« Reply #1 on: July 28, 2014, 11:54:37 PM »
No, but weight is not a factor for Bonneville.  Build it like your life depends on it.... it does.
filmermikey
« Reply #2 on: July 29, 2014, 01:20:27 AM »
well because I'm building a 2 stroke motorized bicycle for the flats, so I was wondering if I needed to build a new custom frame or not
« Reply #3 on: July 29, 2014, 10:30:59 AM »
I suspect the factory frame will pass and be OK for the speeds you are anticipating unless the 2 Smoke is an old TZ.  :roll:
