Hey, Wobbly -
Part of the last iteration of the Grenade included coating the pistons.
Because we notched the piston to accept an exhaust valve that extended deeper into the combustion chamber, and the original piston head thickness was getting a tad thin in that area, my chief concern was to protect the piston from additional heat build up. There were enough other changes made that I can't reasonably say that the piston coating was a contributing factor toward power production, but it did provide some additional peace of mind for me.
In addition to an ever-so-slight increase in CR, and the same fuel for the dyno work in both sets of tests, the total advance timing remained the same, although as I recall, I was able to kick in an additional bit of advance in the midrange.
Granted, we were using 118 octane, and we were not running any boost.
Total timing was 36 degrees advance.
Your mileage may vary, but I'm one of those heretics who believe that durability is a performance factor.
