I got lost at TE.
Mike all of the multipliers change with each rear gear change, Trans gear change, by shifting the trans, or changing the tire diam.
what one is trying to is bring the biggest TE number to the speed on is trying to achieve---
I was able to bring 15 more ft. lbs. by gearing up, tiring down and going back toward peak torque of my engs TQ curve---using this on an excel spread sheet I was able to go almost 6 mph faster most likely due to the old LSR saying:
" It is easier to pull the gear than the tire".
TE is what is put to the ground as the old add used to say it is where---(POWER TO) the rubber meets the road---
the driving force-- so to speak---
does not deal with tire slip or capability
