Things we learned from this thread...
If you have an axe to grind, you will grind it at every opportunity... (I know I do and this is not necessarily directed at JNuts, we should all think about this...)
If you do not talk to the SCTA, they will act without your input.
Everybody wants racing to be safe... it is not, but we should stay on task and try to keep it as safe as we can and still race. Everybody has to do their part.
Think before you change anything after tech inspection
If you do alter your car after tech, even if you don't think it matters, maybe you better check with tech.
You can crash even if you don't think you will... for no apparent reason
The SCTA is not perfect, but it is our sanctioning body, work with it or don't race.
I will not lock this thread, as suggested, but if Jon wants to I will not argue... although I am sure there is more we learned here than I thought of.
