We all know the inspectors look the other way at some cars with obivious rule infractions and get the microscope out for others.
I dont "know" this at all. I don't know of any cars with obvious safety issues that are allowed to race. Maybe you are referring to class legality issues? if that's the case then inspectors don't check for that, only impound does. you can be class illegal and hot lap at Bonneville and nobody would/should care. That only matters when you want to certify a record.
Another aspect should be discussed. What do the rules say about or what is the process whan an Inspector or three make a mistake ? Do you ban them for 5 years, take away their inspection authority, put them up in front of the the board to be chastized.
If you think the SCTA Inspector, therefor the SCTA itself, should be responsible for an unsafe vehicle then the smartest thing the SCTA could do when a competitor presents an unsafe vehicle, and the SCTA believes that competitor will continue to present unsafe vehicles, would be to ban that competitor for life. Because I guarantee you if I were the SCTA and was responsible for someone elses car then I would not let anyone race anything that wasn't 100%, absolutely, gold plated, FEA analyzed, professional engineer certified, crash tested, PERFECT. I would NEVER let a person weld their own chassis. Never let anyone design their own ANYTHING. Is that what you want?
If an inspector isnt doing his/her job then they need to move on, or be moved on, but it's the entrants responsibility to make a safe car. If you figure you are just going to throw some crap together and see it you can talk it through tech then you are in for a bad time and it cant be blamed on the tech inspector.
BTW, none of the above is directed at Hotnuts, I don't know what inspection issues he is talking about, it is a response to jh333's post.
