Author Topic: Altered Class with Pre 82 bodies  (Read 33354 times)
Offline 38flattie
Re: Altered Class with Pre 82 bodies
« Reply #15 on: May 26, 2014, 06:21:24 PM »
So Now I am really confused.
Rules state no turbo's, no EFI, etc with vintage engines in vintage bodies.
So, does that rule really mean, no turbo's, no EFI  in vintage body CLASSES???
So you can take a 37 chevrolet coupe, with a GMC engine, in XX0 or X0 class, run electronic fuel injection and turbos and run it in BGC?  or BGCC?
Simply-YES.
http://youtu.be/89rVb497_4c
« Reply #16 on: May 26, 2014, 06:27:42 PM »
Thanks.
Mr. Warner, I propose that the next rulebook be reworded to the effect of:
"5.D.2.  ALTERED COUPE...This class encompasses American and foreign coupe and sedan bodies 1982 to current year, and coupes and sedan, 1949 to current year, not meeting the criteria of the Classic Category..."
"5.D.3. GAS COUPE...This class encompasses American and foreign coupe, sedan, and convertible bodies 1982 to current year, and coupes and sedan, 1949 to current year, not meeting the criteria of the Classic Category..."
Respectfully,
Mike  :cheers:
Offline xxobuick
« Reply #17 on: May 26, 2014, 06:28:36 PM »
WOW, ok, for years I did not know this.
Offline xxobuick
« Reply #18 on: May 26, 2014, 06:29:18 PM »
Thanks.
Respectfully,
Mike  :cheers:
But this states 49 to current year.  What about 30's cars?
Offline 38flattie
« Reply #19 on: May 26, 2014, 06:33:50 PM »
Thanks.
Respectfully,
Mike  :cheers:
 In "5.D.2.. it also says "Pre-1949 bodies may be chopped.
I already went through all of this, but the best thing you can do, is send your detailed proposal of switching from Vintage to Modified, to Bobby Sykes, drylakes207@yahoo.com.
« Reply #20 on: May 26, 2014, 06:35:17 PM »
Ha!
ok..."1982 to current year, and any older coupe or sedan not meeting the criteria of the Classic Category..."
Offline RichFox
« Reply #21 on: May 26, 2014, 07:51:07 PM »
I ran my 12 port GMC/'32 coupe in XXO/VAlt. No turbos allowed on a vintage engine in a vintage car. My turboed stock head Vega ran in what is now XO/GAlt. As did your Jag. No X classes in the Classic category. Both cars advanced into CC with the addition of a belly pan or pointy nose on the coupe.
Offline xxobuick
« Reply #22 on: May 26, 2014, 09:12:25 PM »
Ok, Rich, So a data management, ie electronic fuel injection can be ran in a vintage body, vintage engine in non vintage classes, such as 38flattie did with xxo/bfalt?  But you cant run turbos?
Where does it specify that in the rule book?  Since the rule book states that you cannot have electronic fuel injection or turbos in vintage engines in vintage bodies?
Offline 38flattie
« Reply #23 on: May 26, 2014, 09:19:40 PM »
No, read what Rich said again=he had a XO engine, in a 1932 coupe, and he ran Vintage.  The TURBO moved it to XO/BGALT, and the bellypan or pointy nose allowed for XO/BGCC
If it isn't allowed in Vintage-EI, Turbo, engine management, etc, the car moves to modified, because there are no XO,XXO classes in Classic.
« Reply #24 on: May 26, 2014, 09:23:29 PM »
"you cannot have electronic fuel injection or turbos in vintage engines in vintage bodies"
That pertains to running in the Vintage classes.
Offline xxobuick
« Reply #25 on: May 26, 2014, 09:43:12 PM »
" For reasons of historical authenticity, vintage engine modificationas and equipment used shal be restricted to older technology levels, so far as practical.  Accordingly, in classes XO, XF, XXF, XXO, V4 AND V4F USING VINTAGE BODIES"
So then it should read:
" For reasons of historical authenticity, vintage engine modificationas and equipment used shal be restricted to older technology levels, so far as practical.  Accordingly, in classes XO, XF, XXF, XXO, V4 AND V4F USING VINTAGE BODIES IN VINTAGE BODY CLASSES "  ?
Offline 38flattie
« Reply #26 on: May 26, 2014, 10:04:36 PM »
Yes, although once you get used to the rule book, it's really not that confusing.
....for the most part! :-D
Offline xxobuick
« Reply #27 on: May 26, 2014, 10:48:31 PM »
Thats kinda a bit of a problem with the rule book.  Once you been doing it for years, its simple, but to new guys like us, its a lot of question asking.  It seems with most of the rules, that with just an added couple words or sentences, can free up A LOT of confusion.  Last year I had the same issue with aluminum wheels and the lug nut question.  After a hole bunch of questions, they now added about 3 more words, and it is not confusing at all.
Offline Dynoroom
« Reply #28 on: May 27, 2014, 01:32:37 AM »
The rule book is a work in progress at all times. When an issue is found corrections are discussed and changes made as required.
No perfect rule book in any organization from Formula 1 to Tractor Pullers.
Offline xxobuick
« Reply #29 on: May 27, 2014, 11:59:34 AM »
I understand completely and am not complaining, but rather just trying to learn.
