Thanks all... I'll skip on the ice skates I suppose...
As for not being able to fit 26" tires for Bonneville... My Bonneville tires are 5" wide, so 28" tall isn't a problem. It's just the concrete track tires where it gets tight as they're more than twice as wide. The fender lips are already rolled for maximum clearance, I can't mod the body further due to class restrictions AFAIK, so I can pretty much only go up in ride height to make more room if that's what's needed... or run a narrower tire. I was blowing the 225 drag radials off when I finally gave it some throttle in 4th gear at 170mph, I need more tire... 255 might do it, but I'd like to fit the 275's if I can.
I may just have to put a little more rake in the car in order to fit Mickeys or R6's. Maybe I'll buy both and see if there's any real difference in fitment.
