Car is "H" engine class. Car currently holds production record of 153+, with an (unknown) sick engine, and no special prep work on the car. I'm currently rebuilding the engine, adding dry sump, scraper, electric oil/scavenge pump, electric water pump, (minimizing parasitic drag), higher (11.7:1) compression, repairing dragging brakes, thinner oil, lowering, etc, etc. I expect to push the "H" Production record to 160-165. The Gas Coupe record is 146+ (which I hold with 3 of the 4 cylinders with blown head gasket and cam that spun 10 degrees retarded), The gas Altered record is 148+, and the fuel Altered record is 159+, and gas Competition Coupe record is 144+, and the fuel Competition Coupe record is 148+, so all records are within reach for my car right now, without aerodynamic aids. It is just a case of how many I can get in August if the car holds together, as I may only have 3-4 days because of drag racing schedule. I kind of need to see which I can modify my car for easily while at Bonneville, and go through class change. I'm just one guy with an 81 year old helper. After I baseline what the car can do, I can go after each record all out, such as I have a 200hp nitrous/NANO kit for the fuel class. Kind of dumb to blow the motor the first time out going for the fuel records, but once you own the record, let it rip!
That is why I am asking what quick (minimal) things I need to do to go to different classes while at Bonneville for right now. I don't have the time right now to build every possible advantage accorded by the rules for each class. It sounds like I can take my Production car, and by adding a removeable step pan made of 1/8" aluminum, and masking tape the headlights, run gas Altered, and then add a mild 35hp shot of nitrous (already installed) I can run fuel Altered. If I have time to extend the removeable step pan to a full removeable belly pan, then I can do the same for gas/fuel Competition Coupe. Does all of this sound right?
Jeff
