Author Topic: My Salt Dream : VW Karmann Ghia  (Read 67627 times)
Re: My Salt Dream : VW Karmann Ghia
« Reply #90 on: September 14, 2017, 12:37:36 PM »
I think I see the quest for a 150 mph record here! Good luck!
Offline wickedwagens
« Reply #91 on: September 19, 2017, 11:12:29 AM »
This weekend we went back for the World of Speed event.  I ran 155.089 and 161.395 MPH for a record in G/CBGC of 158.242 MPH.  I had a top speed of 161.898 at 6800 rpm and only 15 lbs of boost.
1968 Volkswagen Karmann Ghia
G/CFALT  106.643 MPH  8/2016    G/CGALT  113.131 MPH  9/2016
G/CBGALT  169.462  MPH  8/2021    G/CBFALT  146.715  MPH  8/2017
G/CBGC  158.242  MPH  9/2017   H/CBGC  94.334 MPH  8/2018
H/CPRO  93.383 MPH  8/2018   H/CBFALT  101.282 MPH 9/2018
H/CBGALT  120.591 MPH 9/2018
Top Speed 170.726 MPH
36hp VW 100 mph club 9/2019 102.319 MPH
Offline GD
« Reply #92 on: September 19, 2017, 12:16:07 PM »
Congratulations. I was there with the North of 49 car and watched your runs. You hauled ass with that little car. Good job!  :cheers:
Gord
Gord Driedger
53 Studebaker
Record holder Speedweek 2016 XF/FCC 162.698
Record holder Speedweek 2016 XF/GCC 158.978
« Reply #93 on: December 29, 2017, 01:44:16 PM »
Here is the start to the 2018 season.  A destroked crank for my H engine.  66mm stroke x 85.5mm bore for 1516cc or 92.5 cu in.
« Last Edit: December 29, 2017, 05:33:21 PM by wickedwagens »
« Reply #94 on: December 29, 2017, 02:27:09 PM »
The way your motor take boost I fully expect your H records to be very close to your G records!
« Reply #95 on: July 16, 2018, 01:11:02 PM »
Here are a couple updates.  It took a while to collect the parts to build the H motor.  The heads are the last part and UPS says they should be here today.
Piston to cylinder wall clearance is good at .006, and I just need to open the ring gap a little from .020 to about .024.
« Reply #96 on: August 20, 2018, 03:15:21 PM »
H motor was completed a few days before we had to leave.  The new parts needed a bunch of machine work and I was short on time for posting updates.
I took the car down the street and it wouldn't pull past 4000 rpm.  I decided to try and iron it out at Speed Week.  We arrived on Saturday morning and I figured out that I had forgotten my log book at home.  I was able to contact a friend that was leaving that day and he was able to pick it up.  With not being able to go through tech and my wife showing an interest in driving we decided to go through rookie orientation and get her ready if she decided to run.
Here she is doing her bail out test.
My log book made it Saturday afternoon and we made it through tech at the end of the day.  Sunday morning we went to the rookie course and made a pass.  The car went to about 4k and started to nose over.  I shifted to second and it did the same thing.  It was just overly rich and not building boost.  Finally in 3rd it built 5 lbs of boost and the same in 4th.  We made it through mile 2 at 83.331 mph.  With knowing my wife wanted to run and this was an open record in H/CBGC we decided to go to impound.
I changed the main jets from 200's to 180's (the smallest I had) in hopes that it would lean it out enough for the engine to rev a little and get the turbo to spin up.  I also adjusted the boost controller up just in case it was starting to let the wastegate open.
The next morning we went to impound early and got the engine warmed up.  The engine ran better and pulled to 7,000 rpm and the turbo built 7 lbs of boost this time.  We ran 105.337 mph and called it good as this turbo is just too big to spool up on this little engine.  We will be back in September with a smaller turbo to try for some more blown records.  This was Record #6 in H/CBGC at 94.33 MPH.
« Last Edit: August 20, 2018, 03:33:35 PM by wickedwagens »
« Reply #97 on: August 21, 2018, 11:23:29 AM »
With the turbo not building much boost it was time to let the wife try her hand at driving.  I pulled the turbo off and converted the car to normally aspirated.
We went back through tech and got in line.  She did her first run at 96.029 mph.  This qualified her for an open record in H/CPRO and we went back to impound.
The next morning she backed it up.  The car wouldn't shift into 2nd gear so she skipped it and went to third for a bit then back to second.  She was able to still pull off 90.737 mph and set the 7th record for the car in H/CPRO at 93.38 MPH.
We went back after lunch because she wanted to make a clean pass.  She made another good pass. She said it was more fun without the stress! I went to make another pass and we got put on wind hold, so we decided to pack it up and head home.  Overall it was a great Speed Week.  Short lines, great salt, easy going couple of days.
Offline CNC-Dude
« Reply #98 on: August 25, 2018, 10:47:11 AM »
Its a lot funner when you have a spouse that supports and also participates in your hobbies! Great looking car and AWESOME performance with 7 records now. Keep up the good work and reaching for the next rung on the ladder.  :cheers:
« Reply #99 on: August 28, 2018, 11:48:19 AM »
Yes, it is nice to always have her support.
I switched out the turbo for one that I had that is a little smaller.  Hopefully this will build some boost.
I also lowered the car 2" in the rear.  It has always sat a little high and now it sits a little more level.  Hopefully handling stays the same.
Just an oil line to hook up and a new top to make the fuel pressure regulator boost refrenced and we are ready to go for World of Speed.
Offline noboD
« Reply #100 on: August 28, 2018, 12:32:03 PM »
Sounds like you lost your driver's seat.
« Reply #101 on: September 10, 2018, 11:02:29 AM »
We are ready for World of Speed.  I’m feeling way better about how this is running with the smaller turbo. Starts to come into boost at the end of first gear and is starting to make 5-7 lbs after shifting to second gear. We won’t really be able to tell until we hit the salt this weekend, but I’m excited to play with this 1516cc.
https://www.youtube.com/watch?v=WVuvTQ4lvck
« Reply #102 on: September 10, 2018, 11:23:29 AM »
I'm looking forward to seeing your nice KG this weekend!
« Reply #103 on: September 10, 2018, 11:24:13 AM »
Looking forward to seeing you there!! Now with a little boost that 1500 should light right up. I am leaving at O dark 30 on Wed. Hope to get pits set up and through tech on Thrusday. See you in the tech line.
Schimmer and Son I Fuel Lakester 984
« Reply #104 on: September 20, 2018, 04:25:01 PM »
World of Speed 2018.  We arrived Friday morning and went through tech.  After the drivers meeting we fueled up with ERC 110k and got in line.  We made the first pass on the short course.  The car ran decent, but only 7 lbs of boost.  I showed 129 mph on the GPS and went by the timing tower.  They had no timing slip for the car and said it crashed the computer and to go to the front of the line and try again.  On the second run it was a little richer and GPS only showed 125 mph.  We went to the timing tower and the same thing.  No timing ticket and they said it crashed the computer again and then they entered all of my information manually.  We went back to the front of the line again.  By this time it was getting hot outside and the engine was starting to get a little hot.  I noticed that oil pressure was a little lower and the AFR was even richer.  On the 3rd run we finally got a timing slip and it showed 114.431 MPH.  We took it and went to impound.  The next morning the car ran great with the cooler air and we managed a 126.751 mph pass with the same tune.  We went back to impound for Dan Warner to certify the record and #8 for the car was set at 120.591 MPH in H/CBGALT.  I did a class change to the fuel class and got back in line around 12:00.  The winds came up and we were put on wind hold for the remainder of the day.  The next morning we were #2 to run on the short course.  I had been turning the boost controller up a little at a time each pass and it was just starting to raise the boost off of spring pressure.  The pulled hard and ran pretty good at about 8 lbs of boost.  We ran 128.45 mph and went back to impound.  They announced that we could do backup runs at 1:00 pm, 5:00 pm, or the next morning.  We din't know how the wind or weather would be so we decided to go at 1:00 pm.  The thin air killed the car.  It was so rich that it wouldn't pull over 3,000 rpm in 1st and second gear.  Finally in 3rd and 4th it started to build boost.  I showed 129 on the GPS so I figured it made up for it at the end of the run.  When we went to the timing tower and looked at the slip it showed 14 mph average from the 2-3.  We complained, but they said that there were no problems with any other cars so it must be right.  We had to use the 1-2 miles times which were terrible due to the rich conditions and no boost, but we were tired and ready to head back home so we took it back to impound where the 9th record was certified at 101.282 MPH in H/CBFALT.  It was a fun year on the salt.  I'm already thinking about next year and which direction to go.  Do I keep the H engine in and fix the carburation issues and go for 150 mph, rebuild the G engine and see what the real potential is, or build an F engine and go for 200 MPH?  Lots to think about and work on this winter.
