Author Topic: shifter question  (Read 2660 times)
Offline yarp
shifter question
« on: April 06, 2014, 09:29:08 PM »
factory shifters won't pass tech?
The inspection form says all automatics must have reverse lockout.
Offline Captthundarr
  • In line
Re: shifter question
« Reply #1 on: April 06, 2014, 11:05:17 PM »
What class are you planning to run.
Offline MIKE MATY
« Reply #2 on: April 07, 2014, 07:47:41 AM »
If you have to push a button to put it in reverse it has reverse lock out. (ie stock shifter funticon)
ECTA 200MPH CLUB Maxton
A/FRS      205.531
D/FSS      159.427
ECTA 200MPH CLUB Ohio
A/FRS       208.530
2013 Hot Rod Top Speed Challenge Winner
Offline yarp
« Reply #3 on: April 07, 2014, 11:57:56 AM »
Unblown fuel altered
Offline ronnieroadster
« Reply #4 on: April 07, 2014, 05:02:06 PM »
The reverse lockout is an important item. If upon crossing the finish line you decide to shift to neutral during shutting down you need a way to be sure the reverse position is not engaged. Also the possibility of down shifting if the neutral position is missed is another concern. Locking up the rear tires at speed is not fun I know from experience.   :cheers:
Offline runt13
« Reply #5 on: April 07, 2014, 06:05:46 PM »
YES YOU DO!
who would have guessed it would take so long to go so fast for such a short time?
2012 Wilmington mile
April meet,
p/pp-1350/4 record, 132.601mph
September meet,
p/pp-1350/4 record 139.915mph [bump]
p/pp-1650/4 record 142.364 mph
p/pp-2000/4 record 140.009 mph
p/pp-3000/4 record 144.511 mph
2013 Wilmington mile
July meet,
m/pg-1650/4 record 137.278
m/pg-2000/4 record 136.695
Sept meet,
p/pp-1350/4 record 141.1986 [bump]
2014  Wilmington mile
May meet
p/pp-1340/4 record 142.5855 [bump]
  • In line
« Reply #6 on: April 07, 2014, 08:06:20 PM »
What Mike said.......
Offline yarp
« Reply #7 on: April 07, 2014, 09:13:01 PM »
The stock toyota shifter button has definately been disabled.
crap
Anyone in Ohio have a gm 4 speed automatic shifter they are not using?
*looks for the classifieds*
Offline MIKE MATY
« Reply #8 on: April 08, 2014, 10:11:42 AM »
go to any junk yard and get a v6 camaro shifter.  Dime a Dozen.
A/FRS      205.531
D/FSS      159.427
A/FRS       208.530
