Bogart two piece real bolt together race or street wheels. Steel valve stems. Very light weight. Set of four, were used on land speed record holding Bonneville Salt Flats 1990 Honda CRX 153+mph. 15" diameter, 4 1/2" wide, 4 x 100mm bolt pattern, polished aluminum. Also included are the moon disc type wheel covers used at Bonneville. They are held in place by the 3 quick release fastners. The 3 metal brackets sticking up on the wheels are easily removed by unbolting from the wheel. You can run the wheels as a polished rim, or bolt on the wheel discs for an entirely different look. Everything is in good condition, and rims could use a good polish to bring out the mirror finish. Look up the price for new Bogart rims for comparison. 818 363-7572 $600 set of 4 with discs plus shipping
Email for pictures jokerloco9@aol.com
