Hi Sumner, thanks for your response and it is very useful and interesting. At Bonneville my top speed is only 216mph at 4 mile because we reduced the turbo boost to 20 lbs and set the rev limiter down to only 6300 rpm, we also run a Ford 9" with a ratio of 2:47 to put a big load on the single big turbo, we thought we tuned the car for 212mph but got 216 instead, by open spool we only have power to one wheel, some say that good for going straight where if you have power to both wheels like posi or locker rear end, it some times makes the car fight back and forth because of different traction on both tires, but I really don't know which is best. We took the 2:75 ratio out and installed the 2:47 and we did better for top speed, some day if we race again we will move the rev limiter up to 7,000 rpm and give it more boost and more fuel and see if we can do around 225. Again thanks for your inputs, take care, Dave
