Author Topic: Breaking Wind  (Read 193213 times)
Offline revolutionary
Re: Breaking Wind
« Reply #330 on: August 23, 2018, 10:09:04 AM »
The EGTs were through the roof and one of the primaries softened up and pushed out of the collector.
When that happened it was shooting exhaust forward and about melted the fuel lines
We borrowed a TIG welder from one of the other racers and did some field repair
Got it fixed and made a 234mph pass
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
Re: Breaking Wind
« Reply #331 on: August 23, 2018, 10:16:09 AM »
Annnnd on the next pass the same thing happened to the other side....
We fixed it again and ran 237.
The following morning we put some boost in the car and ended up ventilating the oil pan.
Breaking Wind #9614
Re: Breaking Wind
« Reply #332 on: August 23, 2018, 10:18:43 AM »
Still lots of fun overall
Breaking Wind #9614
Re: Breaking Wind
« Reply #333 on: August 23, 2018, 11:16:15 AM »
It's a good thing that it did not burn through that fuel line!
Re: Breaking Wind
« Reply #334 on: August 23, 2018, 11:18:00 AM »
  DANG.. keep at it, you'll get it and go fast.
Re: Breaking Wind
« Reply #335 on: August 23, 2018, 01:39:56 PM »
I know that your headers are stainless steel, which alloy? 321 is what it should be. Radiant heat, powerful stuff, it is driven by differential temperature and the distance between the hot part and any other parts, as I remember if you double the distance you will reduce the radiant heat transfer by a factor of 8, so you need lots of good reflective shielding and ceramic based insulation and lots of distance between parts, like fuel lines and the heat source. Good air flow over the affected area helps, as it cools the affected parts by convection, it has no effect on the radiant heat transfer.
Sorry to hear you windowed the engine.
Offline javajoe79
Re: Breaking Wind
« Reply #336 on: September 04, 2018, 11:21:49 AM »
Definite good points. I talked with Daryl after speedweek and mentioned some 321 schedule 40 manifolds to replace the headers. Hopefully he'll bring me the car again and we can make that happen along with some more thermal management. Big difference in dealing with heat in 1 mile vs 5.
615-210-1605
Re: Breaking Wind
« Reply #337 on: May 10, 2019, 12:22:48 PM »
Been far too long since an update, but it's been a crazy year. Now moved full time to Orlando from TX and had the car back up in Nashville for Coffey Fabrication (JavaJoe79) to make some new exhaust. We ended up with 321ss stepped log style manifolds which are so much more convenient than the headers we had before. Power is not really an issue at this time, so I don't think we will be hurt by the design.
Breaking Wind #9614
Re: Breaking Wind
« Reply #338 on: May 10, 2019, 12:25:55 PM »
You should have seen the rust damage - oof! Destroyed the rear brakes. Not sure why but the front brakes were actually pretty ok. The magnesium case on the Lenco is not too happy either.
Breaking Wind #9614
Re: Breaking Wind
« Reply #339 on: May 10, 2019, 12:30:48 PM »
FYI This is where the rod tried to exit the pan. It just destroyed the block instead...
Breaking Wind #9614
Re: Breaking Wind
« Reply #340 on: May 10, 2019, 05:03:31 PM »
  We've had rust on rotors before but nothing like that :-o
  Did car go thru water or forgot to wash them? We replaced our rears with Mark Williams Interprises brakes.
  No front brakes for us this year as caliper pistons were frozen and can't find replacements with 6'' lug spacing and 11/4
wide rotors.
  Bville salt  :x
  Going to make Bvill?  Car looking good, should be a 300 mile contender. Hope to see you there.
Re: Breaking Wind
« Reply #341 on: May 11, 2019, 02:38:21 PM »
Love the new headers!! 321 plus some extra wall thickness should be a great set up for the "White dyno".
Re: Breaking Wind
« Reply #342 on: May 15, 2019, 01:38:42 PM »
FYI Some pics of the carnage from last year...The end result was junk block, crank, rods, pistons, cam, valves, and lifters. At least the heads were fixable. I had Reher Morrison freshen up the valve job and surface the heads. New cam from Lil John. New Bryant crank, Crane lifters, PAC springs and retainers, Manley valves, Comp pushrods and bought a Dart block from a friend. The new engine is 4.530" x 4.250" ( 548 cid) so just a little smaller that the old 555. Turbos are still in great shape at least.
Breaking Wind #9614
Re: Breaking Wind
« Reply #343 on: May 15, 2019, 02:07:34 PM »
Any idea what started this disaster? Did the cap come off the unbroken rod shown in your photo?
Re: Breaking Wind
« Reply #344 on: May 15, 2019, 02:36:31 PM »
Oof. It's amazing how some pictures make you involuntarily cringe.
Glad the heads and turbos are OK.
