Author Topic: Nice wind tunnel shot  (Read 30780 times)
Offline Bob Drury
« on: March 14, 2014, 01:08:25 PM »
  If you go to http://www.dragracingonline/agent1320 there is a great shot of Alan Johnson's new Mopar Pro Stocker in a wind tunnel that shows amongst other things why you don't want a low scoop on the hood of a race car.  The difference in low and high pressure air is quite evident and also shows why funny cars run such a high wickerbill to gain traction on asphalt.               Bob
« Last Edit: March 14, 2014, 01:10:21 PM by Bob Drury »
Bob Drury
Re: Nice wind tunnel shot
« Reply #1 on: March 14, 2014, 01:52:39 PM »
« Last Edit: March 14, 2014, 01:59:48 PM by sabat »
« Reply #2 on: March 15, 2014, 03:39:29 PM »
How come the guys in these tunnels never hold the smoke generator close to the floor?.
I want to see the air flow around the splitter. :-D
« Reply #3 on: March 15, 2014, 06:41:32 PM »
It's time for SSS to ask another one that many know, I'll betcha.  What's a "wickerbill"?
« Reply #4 on: March 15, 2014, 08:05:00 PM »
Usually $5 to $10, depending on height.
« Reply #5 on: March 15, 2014, 08:34:02 PM »
...rim shot, please!  :-D
Offline interested bystander
« Reply #6 on: March 15, 2014, 08:43:48 PM »
Wicker bill is a Gurney lip. Across the Pond is is a definition of part of one's private parts (male)!
Thanks to the aforementioned Stan Beck who donates his issues of Automobile magazine to the home , this month's  has the intro of the Dodge Dart featured.
Using a well worn phase, if that thing in the tunnel is a Dart, my Uncle's my Aunt!
5 mph in pit area (clothed)
« Reply #7 on: March 15, 2014, 09:16:27 PM »
Male private parts are one thing that I think I know -- but a Gurney Lip?  You guys aren't helping me very much.  Thanks for trying, though. . . :?
Offline Dynoroom
« Reply #8 on: March 16, 2014, 12:52:15 AM »
We would slide in different Gurney lips to balance speed with handling just before qualifying.
Hope that helps.......      :-P
« Reply #9 on: March 16, 2014, 02:15:41 AM »
I`ll try Jon. On most serious race car rear wings there`s an L shaped lip across the trailing edge. It can usually be changed to vary the height and thus the airflow. This has a very noticible effect on the efficiency of the wing. The L shaped piece is a Gurney lip on this side of the pond or a wickerbill over `there`.
Offline hotrod
    • Black Horse photo
« Reply #10 on: March 16, 2014, 02:57:14 AM »
It got its name due to Dan Gurney's use of the technique to quickly tune the down force on a rear wing.
It is a small vertical lip at the trailing edge of a wing (hence the name lip) which significantly increased down force for a very small increase in drag.
It's primary advantage is that they can be engineered to be easily changed during a pit stop to increase down force or reduce it by simply sliding out one lip and inserting one of a different size.
It was a spur of the moment invention that revolutionized racing.
http://www.insideracingtechnology.com/Resources/gurneyflap.gif
http://allamericanracers.com/the-gurney-flap/
« Reply #11 on: March 16, 2014, 09:01:40 AM »
According to conventional wing wisdom it really should not work!  :?
But this is what happens [sometimes] when you deal with hot rodders!  :-o  :-D :cheers:
« Reply #12 on: March 16, 2014, 10:06:03 AM »
“The purpose of science is to explain how hot rodders do what they do.” – Scott Guthrie (IIRC)
gkabbt
« Reply #13 on: March 22, 2014, 07:37:32 AM »
Just saw this thread!
IO.....ROTFLMFAO!  :-D   :cheers:   :-D   :cheers:   :-D
Looks like NHRA is going/has gone the NASCRAP route!
Gregg
« Reply #14 on: April 29, 2014, 06:54:52 PM »
Here's a link to a Bangshift.com page that holds a video of a car that ran for the first time at SpeedWeek '13.  Here it's tested in the A2 wind tunnel.  If you were there you probably will recognise it.  I didn't bother to create a new topic for it - that's why it's on this one.
http://bangshift.com/bangshift1320/watch-incredible-stupidbaker-land-speed-car-get-wind-tunnel-tested-a2-wind-tunnel/
I corrected my error - which Mr. Kitchen was kind enough to point out to me ( not to all of you).  Thanks. :-)
« Last Edit: April 29, 2014, 08:15:20 PM by Seldom Seen Slim »
