Jim, we all run spools. 222 technically nothing. 2 different sized tires on the rear of a LSR is of course a no-no. So is 3/8' toe out. and negative camber on one side and way positive on the other; plus 2 different casters and real quick power steering. You don't even need to hold on the steering wheel of my roadster and it's arrow straight.
One thing is learning scales and how to use them. Cross weight, side bite, etc is very important on dirt CT and I can now see how to make sure my roadster is right. I borrowed scales before and just used the info the best I could but now we have our own and I can make some adjustments and roll the car back on and see if I improved.
I did learn one thing last Saturday and i was confirmed by Joey Legano on Sirsus radio today. We had enough fuel for the main after track pack, hot laps and the heat race. I put in another 5 gallons and that was 35+ pounds we didn't need. A loose car will tighten up as you use fuel and I didn't think of that. That extra weight wasn't needed as your sliding into the turns. In May we will be at Oildale and it's shorter and I'll make sure we are lighter on the tail.....JD
