Author Topic: question on rear bulkhead  (Read 7207 times)
Offline team damage inc
« on: March 02, 2014, 01:00:22 AM »
Was wondering  if in my mustang  its ok to run steel bulkhead  frm floor  up  to  hatch back if  that  is  ok  to  do.  Was told last time  that  the  alum cover over my fuel  tank  not sufficent
ECTA May 2014
 F/GRS 126.1564
LORING AUGUST 2018
F/GRS 136.87 MI. 146.755 MI.1/2
Offline redhotracing
Re: question on rear bulkhead
« Reply #1 on: March 02, 2014, 07:45:00 AM »
I've seen aluminum bulkheads for fuel tanks in the rear,
as long as it's sealed completely I don't see why it would
be a problem. The easiest way to accomplish a bulkhead
is to mount the cell in the stock tank location and build
an access flap for filling up, or mounting a small cell in
the engine compartment. We use a 3 gallon aluminum
cell and normally get 2 runs on that.
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Offline Joe Timney
    • Delaware Chassis Works
« Reply #2 on: March 02, 2014, 10:25:33 AM »
Consider the bulkhead as a firewall:
3.F FIREWALL:
A full firewall to provide a watertight and flame-resistant barrier between the engine and the
driver is required in all categories. All non-production firewalls shall be made of metal with a
minimum thickness of .060 in.. A thickness of .095 in. is recommended. All holes must be
sealed.
3.E DRIVER’S COMPARTMENT:
Beginning January 1, 2014: All driverʼs compartments shall not be open to the exterior
of the vehicle or track surface such that the driver is potentially exposed to dangers
such as fire or debris as well as dust. A rear floor or aft firewall is required in all vehicles
where applicable.
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
« Reply #3 on: March 04, 2014, 12:05:18 PM »
Thank you gentlemen   for  the  info !!   Currently my fuel cell is located in the spare tire well so  im just going to enclose the cell and fuel pump . I have  one other  question  where the  heck do i get  a inertial switch ?
ECTA May 2014
 F/GRS 126.1564
LORING AUGUST 2018
« Reply #5 on: March 04, 2014, 12:29:36 PM »
Junkyard fox body Mustang... Buy several just in case.
Offline Joe Timney
« Reply #6 on: March 04, 2014, 02:40:52 PM »
I should have about 20 to 30 of them in a week...customer emptied a junkyard.
Joe Timney
Offline MIKE MATY
« Reply #7 on: March 06, 2014, 04:53:33 PM »
I have several I think. I can send you 1 for 15.00 shipped. I paid 10 at the yard and 5 to ship to you. I can check tonight, or you can find one in any ford from the 1990s in the pick and pull yard. Just make sure you only get a 2 wire a 3 wire is a pain. I'll check when I get home.
ECTA 200MPH CLUB Maxton
A/FRS      205.531
D/FSS      159.427
ECTA 200MPH CLUB Ohio
A/FRS       208.530
2013 Hot Rod Top Speed Challenge Winner
Offline Captthundarr
  • In line
« Reply #8 on: March 06, 2014, 05:53:47 PM »
If these wonderful gents don't get you hooked up (pun intended) local parts stores got news ones. for about 20-25 bucks.
Offline RidgeRunner
« Reply #9 on: March 06, 2014, 08:40:40 PM »
     Know any demo derby competitors?
     One of the first things the heads up folks pull or bypass when they are prepping a Ford product to run.
« Reply #10 on: March 15, 2014, 08:46:06 AM »
Hey  id like to thank all of  you  for the  info, Ill have to hit parts yard .  hope  to see  u  in wilmington  in  may     thanks  again  guys
ECTA May 2014
 F/GRS 126.1564
LORING AUGUST 2018
