Wow! Ok first is first... Sumner, I wanted you to see the rollbar so you knew where I was at. Second, I'm not as paranoid stopping on the salt than if I was running at Pomona and had to stop a much heavier car at the same speed. The car is 28' long 26" wide and 27" tall. It has a 250+" wheelbase with not a lot of rear overhang and 25 degrees of caster. With the design of the body and the way the car is set up, I'll be able to drive it with one hand. With only rear brakes, panic stops are pretty much out of the question UNLESS I want to put put it on it's lid! As far as sitting too low, I'd sit behind a wall and use a mirror if that's what it took to break records! I'm not building it to be comfortable, I'm building it to be long, low, safe and FAST! I'll figure out the safest, most efficient chute deal and go with that. I do appreciate the input though! Thanks guys!
