Hey Sum! Thank you sir! The mounts will be fully welded then welded to the frame. To remove the swingarm, you just have to take the nuts off the shaft (which is hard chromed so no rust) and slide it out! It's actually pretty simple. Now I'll build the swingarm (around the tube), bearing carriers and shock mounts.
