Author Topic: UPDATED info on the Kawasaki KZ900 LSR bike for sale or possible trade for ???  (Read 17279 times)
Offline Dakzila
  • 1956 Triumph cub
                                                        Landracing Bike
                     COMPLETE TURN-KEY PACKAGE READY TO RUN - $3,500.00-- Trade for ???---or---Best Offer
FRESH TOPEND ENGINE REBUILT COMPLETED JANUARY 2014.
Rebuild included:
1-   Brand New 1015cc Wiseco 12 to 1 pistons (fresh bore of 900cc block). Actual compression about 11:to 1.
2-   Brand New Megacycle cams: 417”lift/268 duration @ .040 “
3-   Brand new Lectron 38mm FBG carbs
4-   Fresh valve job.
5-   Bike now has a 1015cc engine built from a KZ900 so it should fit into the AMA Classic 1000cc class (?)
***Bike has ran a best of 152.2 mph at El Mirage with a smaller bore, smaller cams, smaller carbs and lower compression***.
This is a good opportunity to pick a very nice Kawasaki LSR bike at a great price.
Bike has just been setup to run BUB event in 2014 in the Special Construction Classic 1000cc class.
The bike is self -starting (total Loss ignition) and tracks very straight.
This bike was completed in 2009 and raced at Bonneville and El Mirage Dry Lake in 2010, 2011 and 2012.
There are about a total of 35 actual run on the frame since being built. This is a turn-key motorcycle. It ready to race as is.
DETAILS:
*Bike is located in Las Vegas, Nevada. I might be able to help with delivery to SoCal, Arizona, Utah or Colorado.
*BIKE COMES WITH A BILL OF SALE- THE BIKE IS NOT TITLED.
*Wheel base can be between 68 and 70 inches.
                                             Tires Information as follows:
*Front: Bridgestone Battlax BT45, 100X90X18 V-rated. Shaved at Cowboy Tire by Nate Jones good to 200MPH. Tire
          manufactured in 2008
*Rear: Bridgestone Battlax BT45-R, 140X80X18 V-rated. Shaved at Cowboy tire by Nate Jones good to 200 mph. Tire
*Kawasaki KZ900 engine (Cases are 1978 KZ1000 – A2. Cylinder block is a 1975 903cc  block). A set of spare cases
   come with the bike and they are 1974 Z1-A 900 cases. they have HD main bearing support and will accept up to a
   1200cc block. They can also be use with the stock 903 block.
* Kawasaki KZ900 frame (modified: raked head stock and extended swing arm).  Frame is a 1975 Z1-B.
* Kawasaki KZ900 Head (1975 head, 6mm exhaust studs, shims on top). Stage 1 Professionally ported head. The
   head flows 93 - 94 CFM at .400" lift at 10" of water. Intake boots are port matched.  Head includes: Stage I Porting,
   37mm Stainless Intakes valves, .500 lift APE valve Springs, APE Guides, Viton Seals and Titanium shim-on-top
   retainers
* New Wiseco forged 70mm high dome pistons
* New Megacycle 417 lift cams
* New 38mm Lectron carbs
* New Tygon fuel tubing
* New Magura 1/4 turn throttle
* New throttle cable
* Battery is a High Performance Yuasa Super Seal  12 V - 12 AH.
* Self-starting with total loss ignition.
* Rear brake only. Operated from handle bars.
* Tapered roller bearing in steering stem
* Heavy duty clutch. Installed in December of 2013
* Heavy duty cam chain -- Teflon cam chain retainer
* APE cylinder studs & head nuts
* APE lower case studs & nuts
* APE Heavy Duty main bearing support
* APE low profile oil filter cover and drain plug
* Vance & Hines Pro Exhaust
* Kawasaki KZ900 welded crankshaft
* Dyna S ignition & Dyna coils
* Dyna rev limiter
* MRE lockup clutch
* Fast by Gast kill switch
* Roller bearing clutch pusher
* Basic Performance Solutions Custom aluminum motor mounts
* Heavy duty "Top Fuel" 630 chain
* Fresh wheel bearings in Nov. 2009
* Fresh battery in July of 2013
* Fresh tires in Nov. 2009 (shaved by Cowboy Tires (Nate Jones), class legal for 200 mph).
* Basic Performance Solutions Custom Aluminum gas tanks
* Pingel fuel petcocks (2 ea.)
* Beasley fiberglass seat base
* New upholstered Beasley seat
* Tach
* Clip-ons
* Basic Performance Solutions Custom Aluminum front fork brace
* Two (2) steering dampers
* Basic Performance Solutions Aluminum kick starter block off plate
* Basic Performance Solutions Aluminum switch brackets
* PMFR 35mm Aluminum Fork Damper Brackets
* Custom Aluminum body panels
Contact via Landracing.com or call Buzz @ 702-204-0562
                                          "$3,500 or trade for ? or Best Offer"
Many-Many-Many spare parts come with this Turn-Key package including a Spare set of cases!
« Last Edit: February 19, 2014, 11:38:52 PM by Dakzila »
Offline Dakzila
  • 1956 Triumph cub
Re: Toy Hauler and Kawasaki KZ900 LSR bike for sale or possible trade for ???
« Reply #1 on: February 27, 2014, 06:06:59 PM »
Ok so I've decided to sale my toy hauler also.
The deal will be the 2007 Carson 14 ft. toy hauler (purchased brand new in 2010), the tow dolly and the LSR Kawasaki bike for... $10,000.
Will sale the toy hauler alone for $7,200.00
                                                  INFORMATION ON TOY HAULER:
2007 Carson Rebel (14') toy hauler purchased new in 2010 from Carson.
One owner and very well maintained. Always stored in covered storage lot.
Ready to use, need nothing. Just add water and head out!!!!!!!!
This toy hauler has a microwave built in, from Carson, and a roof Air Conditioner, from Carson.
Spare tire included.
Included is an extra fold down bed (not normally installed in this model).
Tires are good, battery is good and the unit is ready to be used. Needs nothing---add water and head out!!!!!!!
One owner, everything works as when new
Can be towed with a half ton pickup (I also towed it for a year with my Dodge Durango)
Carson Specs:
Model: FR-142
Enclosure Length 7' x 14'
Tongue Length 4'
Overall Length 18'
Tongue Weight (Dry) 450 lbs.
Trailer Weight (Dry) 3,200 lbs.
Gross Weight
(Trailer + Load) 7,000 lbs.
Ramp Door Opening
(W x H) 78" x 72"
Cargo Area Width
(between Walls) 80-3/4"
Cargo Area Width
(between Dinettes) 71"
Cargo Area Length
(to first Cabinet) 7'5"
Fresh Water Capacity 40 Gal.
Gray Water Capacity 22 Gal.
Black Water Capacity 22 Gal.
Single Propane (L.P.G.) Tank Size 5 Gal. (still 1/2 full !!!!!)
Two twin beds
larger table from Carson
Single Stainless Steel Sink
Formica Counter Top
Smoke Tinted Windows
Window Shades
Pre-Wiring for radio (no radio installed)
TV Antenna / Cable Pre-Wiring
Air Conditioner Included
4-Function Monitor Panel
On-Demand Water Pump
6 Gallon DSI Water Heater
Wet Bath
Stone Guard on Sides & Front
45 Amp Converter w/ 12V Battery Charger
Furnace
Microwave
2-Burner Cook Top
2.7 Cubic Foot Refrigerator
Full Linoleum Flooring
Decorative Wall Paneling
Solid Front Wall Window
Double Convertible Bed / one (1) Dinette
12V DC Interior Lighting
Cable Assisted Ramp Door
2 Wheel Electric Brakes
Lockable Service Doors
Powder Coated Wheels
Tie Down Anchors and single motorcycle front tire chock
Deep Cycle Battery
R-7 Insulated Walls & Ceiling
This is a 2007 model year toy hauler but it was purchased brand new in 2010 directly from a Carson dealer.
Again, one (1) owner and well maintained.
702-204-0562
_________Will consider trading for a Mazda Miata, a Harley Davidson or a Harley V-Rod________
« Last Edit: February 27, 2014, 10:23:46 PM by Dakzila »
Unh, Dak -- would you like me to thin the crop of repeats in your post?  I counted four, maybe five, duplicates in the text portion of the For Sale.  I know you really want to sell it, and I know that it's a great deal -- but maybe four times is a tad much. :roll:  Let me know -- I won't touch it 'til you've given me a go-ahead.
Dak -
Can you supply these two dimensions for me?
Back of the inside to the bathroom, and the wheel well to the side of the bathroom.
Graci!
Chris
OK, fixed the repeats before I saw Jon's post  :|
MM... it fits a couple of single beds, that should be bigger than the Midget  :-D  :cheers:
It looks tight, but man, if I CAN fit it in there, it certainly would save me some dough in the long run.
Plus, to double as a camper?  For a couple of additional trips a year up nort' in the spring and the fall, I might actually be able to keep the Mrs. on board with this whole deal!
Offline Dakzila
  • 1956 Triumph cub
Dak -
Graci!
Chris
Chris,
From the inside of the rear door (ramp) it's 7' 4" to the first cabinet . It's 48" between the wheel well and the cabinet.
Hope that helps. Let me know if you need additional info.
Buzz
Offline Dakzila
  • 1956 Triumph cub
Yes! Yes and Yes!!!!!! Please fit. Not sure how it happened.
Buzz
Offline Dakzila
  • 1956 Triumph cub
Thanks for the help Stainless....ya done good!
Buzz
Offline edinlr
This is off the subject, but your picture of the bike dolly had me wondering, does it turn alright with it being a straight mount to the hitch, or would it be better with a ball mount?
Experience with both types has shown us that having the trailerette (as we call it) fitted with a ball receptacle that goes to the ball on the truck's hitch turns better.  With the solid mount the bike wants to lean over during turning, and that ends up trying to stretch the tie downs on the outside attachment 9to the bike by the straps) and lets the inside strap be loose.  Without care the bike gets loose and tends to flop to one side.
If I can find the photos I can show you the scars on the bodywork from when it happened.
Offline Dakzila
  • 1956 Triumph cub
Not sure if the ball mount would work better or not. I've used this setup for three years at El Mirage and Bonneville and have never had a problem. It wouldn't be hard to put a ball hitch on the dolly and try it.
Thanks for the suggestion,
Buzz
Offline edinlr
Thanks Slim and Dakzila, I had a hitch mounted tow carrier I used last year for one pull.  It scared the crap out of me as it leaned over.  I could use it, but had to really pull the tie downs all the way down and still looked out the rear view a lot.  I decided pulling the big trailer gave me more peace of mind and was much easier.  Seeing your trailerette made me wonder about just putting an axle and wheel on my old hitch and then adding a ball mount for safer turns.  Sorry again for the interruption and good luck selling your bike and trailer.  If the porta potties were not so clean at Bonneville, I am sure my wife would have me looking at your trailer for that reason alone.
Offline 1212FBGS
    • http://www.motobody.com
still got 'em Buzz?
Offline Cereal KLR
Hi Buzz,
I sent a gentleman named Ken your bike info, he will be in contact with you this week.
Jim
I thought I would die young, but now its too late.
