Tauruck: you`re welcome
. Initially had a budget around 8k, 2 for the airplane ticket and car rental, another 2 to ship the bike, and 4 for accomodation and general living, but it does look like it`s slipping a bit, soooo 10 maybe, and I´ll be living on beans for the rest of the year
Koncrete: Yup, that`s an old Royal Enfield. It used to be in a street bike frame, and was used for classic dragracing, until I built this frame to go from "street legal class" to open/top fuel. Stopped working on it after SW 2012 when I started on the B40. It`s a 1946 model J2, so would be old enough for vintage, but it`s been so modified it wouldn`t be allowed there (it would also be in Altered and not modified like the BSA). Head and crank are Jawa speedway parts. Cylinder is aluminium. Piston is modified Wiseco, it has 11:1 compression and Hitchcocks competition cams. Runs really well, and would be a pleasure to race at Bonneville.
Wheels are Kaw 1000 up front, and Yam 400 at the rear, both 18". The sprocket was 15 mms off, but there was enough material to turn down the hub without weakening it at all, it may actually be stronger with the sprocket closer to the center. Another thing that may be of interest to you, is that I went from 5/8 to 1/2" pitch on chain and sprockets. This leaves room for up to 23 teeth (I`m running 22) on the front sprocket instead of the max 19 I believe you can get in there originally. Believe the smaller sized sprockets help keep rolling resistance low, and probably reduces chainwhip.
No need for 17`s for me just yet, haha. Tires are rated (if I recall correctly, will check it out if you want me to) up to 240 km`s an hour or like you mentioned 149 MPH
Briz: Thanks for the info! The quoted 4k is for seafreight!
. I actually have put your number on my cellphone, and considered calling you asking if you got any space left in your container. Just hate the thought of having to ask such a big favour from you guys, and would only ask as a very last resort. Would be great to join up with someone else though. Have asked for Swedes on the Bonneville 2014 thread to see if someone wants to share a container. Have also contacted another shipping company today, and hope that solves it.
WW: Thanks for mentioning that. I was very careful getting both adjusters just right, and when measuring like you showed from adjuster to frame, have the wheel dead straight when both are adjusted the same. You have to be lucky sometimes
. I used a straight piece of flat aluminum for checking. Heard once that flourescent lightbulbs are very handy for this. They`re either straight or broken
