Author Topic: 2014 AMA Supplemental Regulations - Revised  (Read 4512 times)
Offline donpearsall
    • http://soundappraisal.com
« on: February 13, 2014, 11:19:34 AM »
I just noted that the BUB site has uploaded a revised rule book.
http://www.speedtrialsbybub.com/2014_event/AMA-BUB-SR-2014-v2.pdf
I have not seen all the changes but the "A" special construction class has additional requirements that appear to make it easier for OEM frames to qualify for the "A" class. Here is a section from the rule book:
The use of an O.E.M. frame in the Special construction class must have a minimum of two of the following.
    - 2 engines with a combined displacement not to exceed 3000cc.
 - Seat base is lower than an imaginary line drawn between the tops of the rims.
 - Engine and Frame are from different manufacturers.
 - Altered steering head angle.
 - Altered Main Frame engine/transmission mounts and tubes. The main frame is defined as the connection from the steering neck to the engine mounts and swing arm pivots.
 - Non O.E.M. fuel tank not using the O.E.M. mounting points.
 - Center hub steering.
 - Wheelbase exceeding factory O.E.M. dimensions by more than +10%. Measurement will be taken at the most forward axle setting. It shall be the participant’s responsibility to provide proper documentation listing specifications.[/li][/list]
Thank you Rex, Drew, and all others who helped to clarify this area.
Offline Old Scrambler
  • Going Fast - Slowly
Re: 2014 AMA Supplemental Regulations - Revised
« Reply #1 on: February 13, 2014, 05:25:12 PM »
Much Better :-) :-) :-) :-)
Offline nrhs sales
« Reply #2 on: February 13, 2014, 07:11:24 PM »
It is so nice to have an organization that listens to the racers concerns and will make changes quickly.  :cheers:
Offline **RP**
« Reply #3 on: February 14, 2014, 08:25:46 AM »
This rule change is good and was surely needed.  It is similar to the SCTA frame rules in quite a few ways.  It makes things a lot easier to build a bike that could easily be legal to run with both organizations.  Nice to see somebody is listening.
Ralph Pitlock
www.paintworkz.com
Offline Marty
« Reply #4 on: February 14, 2014, 09:15:59 AM »
Well it looks like I'm just fine running A class!!!!! It is refreshing to see some spread between A and M classes. Thats my take on it.
Offline slimjim
« Reply #5 on: February 14, 2014, 09:17:50 PM »
Wow!!! :cheers:My bike might be legal to run this year!!! I'll have to check the streamlining section to see if that's changed as well.
