I do hope somebody in the know does answer the above question about steering head angle. Would a set of offset triple tress that gave say 2-3 degrees more rake angle qualify or do you need to actually cut and modify your steering tube if using a stock frame?
I may not be the "in the know" guy, but -
Since no minimum or maximum change in steering head angle is specified, one would think that whatever additional degrees you added would qualify as a changed "steering head angle"
I personally would NOT consider raked trees as being the same as changing your "Steering Head" - Fork trees are a totally different structure then the "Steering Head"
As for a "custom built" frame - I would tend to think that would fall into the "Purpose Built" terminology.
I am with ya Dan as far as sometimes you can over think something.
Sure we have to be prudent with the time on our builds. I like to just dissect the line and focus on the key words..
When in doubt pm the Tech Steward, he's right here at Landracing .com - & a nice guy, or e-mail the AMA and ask Ken.
Have fun
Jimbo
