Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Bonneville Motorcycle Speed Trials
Bville Motorcycle Speed Trials Rules Questions
(Moderator:
Modified Classic Gas engine mods for BUB
« previous
next »
Pages:
1
2
Go Down
Author
Topic: Modified Classic Gas engine mods for BUB (Read 13597 times)
mtkawboy
Re: Modified Classic Gas engine mods for BUB
Reply #15 on:
February 26, 2014, 02:20:26 PM »
I could be wrong but I believe the stock displacement of an early 750 Honda is actually 736ccs which might give you a little room for clean up but I doubt .050
Chris V
Reply #16 on:
February 27, 2014, 10:52:08 AM »
Mtkawboy:There are websites you can google (I don't know how to add links) ask for engine cubic inch calculation and inch to cubic centemeters calculation.
Last year (2013) I had a set of 1mm over for the classic class ready to swap to replace stock 347cc cylinders (72 R5 350 Yamaha)that makes it 358cc last year rule lowest dissplacment was 500cc now BUB has a 350 classic class. now I,ve got new wossner pistons and nicosil plated cylinders sitting on the shelf. :cry:Chris
1972 Yamaha R5 350cc
Old Scrambler
Going Fast - Slowly
Reply #17 on:
February 27, 2014, 12:03:56 PM »
Mtkawboy...............You are correct about the 736cc...............but the .050" overbore allows me to go as big as 772/ A 1mm overbore is 761cc. So for the CLASSIC class I am OK to go.
I am also OK to use this motor with a BIG-Bore kit and compete in the 1000cc category.
What I see as a problem that eliminates several bikes from being able to compete is .............if their stock motor is called a 750 (or a 350; 500 etc) but its actually a few cc's larger, it can only compete in the next larger category but is limited to the 0.050" overbore. The same would apply to a Liter bike that is actually 1001cc or larger in stock bore.
Chris V
Reply #18 on:
February 27, 2014, 12:40:40 PM »
Sooo I'm I reading the rule correctly that even though my bike is legal in 350 class stock 347cc, I can also run in the 500 class with my 358cc
mtkawboy
Reply #19 on:
February 27, 2014, 12:57:59 PM »
I haven't seen the rules for this new class, where can they be seen at ? What is the max cc and newest year bike that can be run such as GSXR Suzukis ? Never mind, I see them listed below in another post.
Last Edit: February 27, 2014, 04:54:58 PM by mtkawboy
Old Scrambler
Going Fast - Slowly
Reply #20 on:
February 27, 2014, 02:14:32 PM »
ChrisV..............I believe you can only qualify for one class with a specific bike.............but if you have a set of near 499cc pistons and jugs to swap, you could give it a try. Ask the AMA/FIM guru.
nrhs sales
Reply #21 on:
February 27, 2014, 03:45:10 PM »
if you change out the jugs and pistons to make it even 1 cc larger than the limit then yes you could run it in 350 and 500 classes.
Chris V
Reply #22 on:
February 27, 2014, 11:01:42 PM »
Thank you NHRS we just want to run in whatever class we can and maybe snatch a record. were up there to have a good time, Great Granny Sandy and I have hardly a day goes by that we don't talk about what were doing to the bike and plans for next BUB. Chris
Pages:
1
2
Go Up
« previous
next »
Landracing Forum
(Moderator:
