Here is an interesting experience driving superchargers with multi-rib belts.
Years ago, I built a 3.4 V6 Corolla with my son, Matt. In order to make room for "stuff", I chopped off the original fan coupler pulley mount (on front of engine). I then built several belt drive systems that didn't work while running his blower at 9.5 lbs (sea level). Note that I converted from 4-row belt to 6-row (by using a crank pulley off a Camry aluminum V-6).
It kept spitting belts when trying to run the blower above 15,000 rpm. I tried multiple positions of a tension idler, on the "slack side" of the belt. One day, I lucked out and caught the belt partially walked off as I shut down the engine. It was walking off on the straight run "pull" to the crankshaft.
After more experimenting, I learned the belt liked a back side tension roller, just after it left the blower pulley (see pic below). I suspect this reversing of bend, under highest load, was restraightening the web inside the belt. The tension idler position ended our belt problems with this car. It was a cute car, and BAR certified legal...anyway, this belt system worked for years and almost 80,000 miles after the conversion.
Perhaps it will work for my new project, as well.
