I have heard rumors that it takes 200 HP to run a large set of turbos and significantly more to drive a supercharger. I know that is a fairly wide open statement, it really would depend on the turbo size, the target boost, the CFMs..., just for arguments sake, let's say that number is pretty close to 200HP. (If it is not, I will gladly take the corrections to the numbers and some data to back it up!
I would think that by the time you put the weight on to run a pony motor of 200 HP and package it all in, you would be further ahead to just plumb the "compressor" in a traditional fashion. Additionally, if the rules allowed a pony motor to drive the compressor, I would assume that the total displacement of any and all motors would be considered in determining the class.
Several years ago, on another thread I raised the idea of using a turbine engine (APU/GPU) and using the bleed air from it as a charging source. You can get a 200 HP APU in a small form factor that could easily be packaged into a vehicle. This would mean that there is no turbo/supercharger, only the excess compressed air from the turbine engine. The problem is, even if it were legal, you would have to run in the omega class, so there is no real gain from the exercise.
Fun mental exercise though...
