Author Topic: Motorcycle Tire Recommendations  (Read 7489 times)
Offline Scottie J
« on: December 07, 2013, 01:00:13 PM »
I was just curious what tires and wheel sizes different guys are running on their bikes for the salt.  Also any tips/experience as far as hooking up/spinning on the salt you can provide would be greatly appreciated.  Thanks!
Scottie
Re: Motorcycle Tire Recommendations
« Reply #1 on: December 07, 2013, 01:33:36 PM »
A lot of folks like the Bridgestone 003 DOT race tire. You might have luck with the search function for more details, this has been discussed here a few times. -Dean
Offline donpearsall
    • http://soundappraisal.com
« Reply #2 on: December 07, 2013, 01:40:51 PM »
Scottie, I have used Bridgestone Battlax BT-023 and the BT-003R tires most of the time. These are hard rubber tires that have Z speed ratings which you need for your project goals. Although I have had one rear tire shaved, another set was not and still has held together for many runs.
Don't use a soft compound tire whatever you do (like I did for one run). It will melt and explode.
Offline Scottie J
« Reply #3 on: December 07, 2013, 03:14:46 PM »
I have to ask about the blow out Don, how did that run end?
Scottie
Offline donpearsall
« Reply #4 on: December 07, 2013, 04:34:27 PM »
Well it was not exactly a blowout at speed, but the tire delaminated, melted, flew apart, whatever and was flat at the end of the run. Here is a pic of it.
I thought I was OK to use an actual drag racing tire since they are made for these speeds and racers do burnouts with them. Wrong. What I failed to realize was that drag racing tires are in use for only a few seconds, while LSR tire must withstand heat and speed for a few minutes.
Offline maj
« Reply #5 on: December 07, 2013, 05:17:35 PM »
Scottie what bike and intended speed
Offline Scottie J
« Reply #6 on: December 07, 2013, 06:20:28 PM »
1959 Royal Enfield/Indian Chief MPS-PBF.  I plan on doing 150mph+.
Scottie
Offline JimL
« Reply #7 on: December 07, 2013, 08:27:46 PM »
Simpler answer here, if you built an A bike you can use late model components.  It would work for BUB or SCTA.  Proper tires fit up just fine.
JimL
« Reply #8 on: December 07, 2013, 08:53:03 PM »
JimL
Jim I liked the original longer answer myself before you edited it down to the 'simpler answer'  :-).  I didn't understand it all not being a bike person but could see that it was a good overview of maybe not boxing yourself in and sounded like a well laid out plan,
Offline JimL
« Reply #9 on: December 07, 2013, 09:17:20 PM »
I apologize, but it was kinda long and rambling.  I get too stuck on one idea, sometimes, and other folks have their own plan.
JimL
Offline Scottie J
« Reply #10 on: December 07, 2013, 09:40:32 PM »
Damn!  What did I miss?  I enjoy long detailed opinions.
Scottie
Offline JimL
« Reply #11 on: December 07, 2013, 11:44:15 PM »
You missed the jaw flapping in between "if you...." and "it would work for..."
I have had mediocre luck with M class speeds using my pushrod engines.  I think that trying to compare an M class Hayabusa, or whatever, to an M class pushrod or Classic is not apples to apples.
Read through the build diaries on various A bikes for some interesting ideas.  It would probably save you money and time.
JimL
« Reply #12 on: December 08, 2013, 12:07:21 AM »
Jim L, you have a lot more credibility on this site than you give yourself credit for. Your long involved answers always have some very useful information and they promote thinking. That's a good thing.  :cheers: :cheers: :cheers:
« Reply #13 on: December 08, 2013, 01:11:34 AM »
Yep
« Reply #14 on: December 09, 2013, 01:12:30 AM »
No can find Jim's rambling response.  Hopefully this does not duplicate what he said.  Tubeless tires run cooler, are lighter, and are more resistant to sudden pressure loss during a blowout, as compared to tube ones.
Right now I am running a British bike with tubed tires, spoked wheels, and traditional tire sizes.  The setup seems safe with BT-023's and speeds in the 140-150's.  Would I run this arrangement at 200 mph plus?  No.
It would be a good idea to build your chassis around rims that use tubeless tires of sizes where plenty of rubber is available for the speeds you plan to go.
