Author Topic: Fixes to some of the gear/rpm/speed Spreadsheets....  (Read 6029 times)
« on: December 05, 2013, 12:26:24 AM »
I recently became aware that there might of been problems with some of the car spreadsheets like above not updating in the area to the right of the arrow as changes were made to tire size, rear gear ratio or other gear ratios.  I think that is now fixed and the spreadsheets might work better under the Excel format now that I'm using Open Office to save them in that format.
Also the rpm column just to the right of the arrow is a convenient way to see mph speeds at any shift point you desire (just change one of the current ones in the column to the RPM you desire).
Please let me know if you are having problems with these spreadsheets and also you probably will have to download them and then save them before you might be able to use them,
« Last Edit: December 10, 2013, 01:56:18 PM by Sumner »
