Wasted spark with a blown engine, is trouble....been there done that...................
Question for bak189 (and others):
Which electronic ignitions for British twins, 360 degree firing order, do not use wasted spark? Originally, the British twins had dual points triggered by the cam, so no wasted spark. The electronic Boyer uses two coils wired in series (as I believe does the Pazon), and both coils fire at 360 degree crankshaft intervals, so are obviously wasted spark. Even on my single, the Boyer fires every 360 degrees of crank rotation, (the reason for which I don't know, unless Boyer uses the same triggers for both singles and twins to save money!) I believe the early Japanese four cylinder bikes used dual coils which fired two cylinders on every rotation of the crank, so again, wasted spark. I can't picture how any crank fired ignition can avoid the dreaded wasted spark, unless an ECU is used that can distinguish exhaust stroke from compression. So if the wasted spark causes problems with supercharging, how is this solved? Please enlighten me, as I might want to know this in the future.
