The mains are 1.875", not metric.
The crank is nodular cast-iron, and I don't want to be in the same state when it turns 9,000 RPM.
The original rods are aluminum alloy very much like those used by Triumph, Ariel, BSA, Norton twins for 50 years.
200 is going to need at least 1 of the following:
1. second engine
2. turbo or blower
3. large dose of nitrous or nitromethane
I note with alarm the recent trend to invoke the "dynamic compression ratio". It makes wonderful bar stool conversation, but has very little application in LSR.
It also requires you to know, prior to the calculation:
1. static CR
2. stroke length
3. rod length
4. intake valve closing point
Doing some numbers very quickly, an IVC about 55° ABDC will drop the DCR to 13.5
16:1 is going to require a really tall dome, and (if possible) a second plug location.
The valve reliefs will probably need to be hand-fitted as closely as possible to the actual valve curtain "footprint" at its point of tangency to the dome.
Examine your head bolt pattern very closely, and google about this - I think I remember extra bolts added to prevent gasket failure.
A bigger rocker will take some work, but space typically isn't the problem, because the new rocker will be smaller in stature. The ratio is raised by shortening the distance from the pushrod adjuster to central shaft. You may also wish to re-clock the lever angles to prep the geometry once your lift is known.
