I finished stripping down the GS550 yesterday. The frame is now bare except for the motor which is only being held in buy 4 bolts, just need an extra set of hands to yank it out. Looks like the swingarm and wheel should switch right over to the Chief with minimum modifications. I haven't been able to compare the 2 side by side yet, but it looks like the width of the swingarms where the pivot bolt mounts to the frame are about the same width too. I'm pretty sure I can get it bolted right up with maybe a couple of bushings for the pivot point. I'll just need to weld in an upper shock mount to mount the mono shock in the center of the seat area. The best part of using this swingarm is that aside from the mounts being close to the same sizes, the GS swingarm is exactly 5" longer than the RE swingarm. The +10% wheel base rule gives me a MAX of a 6" stretch on the bike. The GS swingarm being 5" longer than factory should get me long enough to help stabilize for high speeds, but without breaking the rules. Or further more,
not being so close to within the rules that the officials may question the legality of my build.
It will take a little more work to get some custom rear sets mounted nice and far back. They will be mounted up about 6.5-7" ahead of the rear wheel axle, which will move them back about 14" from the original foot peg location. I will also be mounting clip-on bars that will be mounted as far down on top of the lower triple tree as possible. This combination should allow my 6' tall body to lay out nice and flat on the bike with a real tight body tuck. This is important as I've decided to break my first few records without a fairing, so body positioning is going to be crucial for trying to cut through that salty air.
I can't believe it! Seriously!
So I went back out and played in the garage for a little bit this afternoon to take some measurements of the swingarm. The factory RE swingarm is exactly 8 1/2" wide where the pivot bolt mounts to the frame. The Suzuki swingarm?
8 19/32"!!!! Not even an 1/8" wider than what is already there, practically a
PERFECT fit! Also, not going to get the 5" stretch that I thought I was going to. It's just shy of a 4" stretch from axle to axle. Not quite as long as I was hoping, but 4" is better than what was there. The large bracket on the bottom of the swingarm is going to get removed. The set up had this super goofy triple hinge shock mount thing going on. Complicated and unnecessary weight, so I'll be mounting the shock to the bracket on
TOP of the swingarm and the top of the shock will be mounted under the seat.
Scottie
