Some of the problems Iv'e had using a draw thru system include, borderline excessive vacuum between the blower and carb (20"), resulting in difficulty jetting correctly maintaining a clean transition from pilot, to needle jet.
Although I've had a few backfires with the BOV earning its keep (not good for the pulse rate) they usually occur during startup.
Don't expect to use the same carb jetting/carb that worked fine before adding the supercharger, blowers write their own tuning rules, 2 years, and I'm still learning.
I'm trying a wideband 02 gauge to help me get things right, but after several startup, run, test and tune rides, totaling 1 hr in total, the condensation methanol makes in the exhaust while the engine gets to operating temp has killed my sensor, even though I took every precaution to avoid this problem, which could be an on going expense if you use efi and methanol , but I feel this is the way to go.
Hey, its all FUN ! , 60 years young and still learning,,,,,
Tiny
