Author Topic: T-shirt art and production question  (Read 7729 times)
Offline salt27
Re: T-shirt art and production question
« Reply #15 on: December 08, 2013, 06:13:53 PM »
Jon,
If it's not too much trouble would you mind showing us some examples of the shirts you've done.
I understand that you can do Under Armour.
We were wanting to use red and white on a dark grey shirt.
So bleeding might be an issue.
Thanks, Don
« Last Edit: December 08, 2013, 06:23:27 PM by salt27 »
« Reply #16 on: December 08, 2013, 06:40:51 PM »
Don, I have someplace a bunch of photos of the shirts we can do, but first of all I'll mention that we aren't "painting" the colors on the shirt but rather dyeing the fabric with color.  That's a good thing because the "paint" - a/k/a silk screen ink - can wear and flake off.  The dye is heated to a gas that permanently colors the fabric.
But -- when dyeing the base color of the item (shirt) doesn't change.  So, for instance, if I tried dyeing a red shirt with red dye -- you wouldn't see much at all.  If I tried dyeing a red shirt with blue -- you'd get a grungy looking brown or something.  And so on.  A dark grey shirt would work - sort of - because we'd start with a dark fabric that can only get darker with the addition of a dye.  While there are (supposedly) new methods and inks available to dye dark fabric, we haven't tried any of them so can't offer the process - nor even say how well it might work.  As for bleeding -- no, that doesn't happen much at all with our process.
And there aren't any white dyes, either, until you're getting into those same kind of brand new products with which we don't have the techniques yet.  White shirts do they best in our process.  I'm at the house now, but will look at the vendor's catalog tomorrow to see what's what.  I know they offer some colored shirts, and if so -- maybe they've got recommendations on how to dye those dark shirts.  I'll let you know.  In the meantime, here's this year's Salt Talks shirt.  This is the first shirt we did -- might not have all of the color balance correct yet.  But it's the only photo I've got here.  You can see, though, that we can do a full spectrum of colors, not the few that silk screens are limited to using.  They do three or four or five basics and can sort of overprint one with another to get a third shade, but only to a certain extent.  No limits with ours.  And by the way -- we use polyester fabric.  The more polyester the better.  100% is great, 50% is acceptable if that's the best you can find, and much less than that won't work worth a durn.  Under Armour is 100% polyester.
« Last Edit: December 08, 2013, 06:43:52 PM by Seldom Seen Slim »
Offline salt27
« Reply #17 on: December 08, 2013, 06:56:36 PM »
Jon,
 Do you have access to "Under Armour" shirts or would we need to supply them?
Is there a minimum order.
 Thanks again, Don
« Reply #18 on: December 08, 2013, 07:22:43 PM »
Well, sure -- we can get the shirts -- but so can you.  We'll make our thousands of dollars on the sublimating (:roll:) and not the shirts.  We can find dang near anything on the internet -- and so can you.  Heck -- check out WalMart.  There's a good source for 'em, and usually fairly inexpensive.  If you want to buy them you'd be welcome to find a source, check with us before buying them so that we can assure you and us that they're the right stuff, and then you buy 'em to be either drop shipped to us - or use the WalMart "site to store" function where you buy them online and we pick them up at the local WM.
The only time there'd be any reason for a minimum is if you were getting large quantities - like 50 and 100 and such, because then we'd use an outside vendor to make the dye transfer sheets and they have price breaks at various quantities.  Otherwise -- 1 costs the same per item as do 5 - or 13 - or 22 - and so on.
Another point you haven't mentioned but I will -- when you finally get your art done, please have the artist save it as a jpeg or bitmap or something like that.  You/he can email it to me, I feed it into Corel Draw and do any other stuff you want (text that the artist didn't put in, etc), and then print it on our Ricoh dye sub printer.  Standard printer, sorta, but fancy ink.  From printer to press and then -- viola, a decorated shirt.  Got it?
