So now I have a question regarding wheel skirts:
2.G WHEELS: deleted sentence NONFERROUS WHEELS: All non-tapered lug nuts that come in direct contact with the wheel shall have a ¼ inch thick steel retaining plate or large OD heavy gauge individual washers under all lug nuts. (This does not apply to spindle mounted nonferrous wheels.) Magnesium wheels are not recommended and, if used, shall have an initial Zyglo certificate and stamp available. Zyglo inspections made with tires mounted are accepted. Wheels are to be re-inspected if any adverse condition arises. It is recommended that tire pressure used on two-piece wheels NOT exceed 60 PSI or manufacturer’s specifications. WHEEL COVERS: The prohibition against “wheel covering” in some class rules does not apply to “full wheel” discs, which are legal in all categories if securely fastened to the wheels with six (6) or more machine grade screws or three (3) Duzs-type fasteners. Inner wheel discs shall be securely mounted to the wheel or axle. All hubcaps shall be removed. Fender skirts are not allowed except in Streamliner class.
So on the rule change page, the phrase "fender skirts are not allowed except in streamliner class". This rule has been crossed out (as above), so does that mean in any class that skirts are accepted?
TIA
Clay
