Author Topic: Weaver oil pump.  (Read 3526 times)
Weaver oil pump.
« on: November 14, 2013, 12:10:45 AM »
I'll be using a Weaver 5 stage oil pump on my motor. I don't have pulleys for the setup yet.
We should be running at 8000RPM max (on paper!).
Does anyone have info on what pulley ratio I should run?.
Buying the wrong parts could create all sorts of problems and returns from this side of the planet don't work that great.
Thanks all.
Offline Dynoroom
Re: Weaver oil pump.
« Reply #1 on: November 14, 2013, 12:21:20 AM »
Depending on the type of engine most systems run between 50-60% of engine speed with a max pump speed in the 5000 rpm neighborhood.
A 28 or 32 tooth pulley is normally used on the pump with the crank gear as required.
Offline Buickguy3
« Reply #2 on: November 14, 2013, 09:39:38 AM »
    Some information here.
         http://www.petersonfluidsys.com/drive_stankit.html
                   [America]
« Reply #3 on: November 14, 2013, 12:01:16 PM »
Thanks Doug. :cheers:
Offline racefanwfo
  • jenks worlds fastest pitbull
« Reply #4 on: November 14, 2013, 02:44:57 PM »
mike i called weaver brothers and talked to yvette weaver and she says the pullys that you should use are 18-32 which will give you a ratio of 56%. the 18 tooth pulley is $36.15 and the pump pulley is $79.64
yvette says if you have any questions you can e-mail her at oilpumps@yahoo.com or if you want to call them there number is (775) 883-7677. hope this helps.
regards michael aka racefanwfo
The speed that you wish to achieve is only limited by the depth of your wallet.
« Reply #5 on: November 14, 2013, 10:00:44 PM »
Hey Michael, Thanks for doing that. I haven't been able to reach Weaver via email. This info definitely helps. :cheers:
