The children and coming by for trick-or-treat dressed like little cats, bananas, etc. They sure are cute.
This engine is pretty efficient. The blue dyno curve is the best main jet size. The needle was shifted to get the red curve and it is the final 2013 setting. The mixture does not need to be overly rich to make the best power. My figuring is the atomization is pretty good. The carbs do not have the obstruction from throttle plates in the venturis, they have only little needles, so the carbs look like the best power producing option for now.
The displacement and static compression ratios for the three engines I have built did not change during their lives. The improvements were in getting more mixture into the cylinders. The BMEPs calculated by PipeMax increase during the engine lives as I made improvements. Is the BMEP is sort of like the third compression ratio I am looking for?
The changes in BMEP through the engine lives are not shown. This is some data from PipeMax for the three different engines:
The final 790cc build: VE = 108%, static comp ratio = 9.2:1, BMEP = 183.8, octane requirement = 91.0 to 91.8
The final 865cc motor: VE = 109%, static compression ratio = 10.5 :1, BMEP = 194.6, octane requirement = 95.8 to 96.5
The 995cc build in 2013: VE = 105%, static compression ratio = 10.5:1, BMEP = 181.5, octane requirement = 95.5 to 96.5
