I also had pulling problems with my Charlie Toy setup. I had to flatten a bulge area, near the left handle bar, by fitting 1/4" solid steel rod stiffeners. Both sides are very close to even and have very similar flatness.
I added a reinforcement rib, internal, in the front fender. It was made by grinding the inner glass surface, rigging a duct tape "dam" (sticky side is the layup side), and forming the rib from fibergass tape with epoxy resin. This keeps the front fender from moving (had major tire rub marks inside, both sides, after running 150 without bracing the fender.)
I should mention that the first correction I made, for gradually increasing "pull" at speed increase, was correcting lateral balance. I had to add ballast to the left side of the bike to get it to run straight without pushing on the right handlebar. If the bike has to lean to run straight, gyroscopic precession will be torque against the bars all the way through....faster you go, worse it gets. The front wheel is trying to fall into the lean.
Right-left balance and straightening the fairing made the bike run very straight this year (except in Saturday wind). It was running about 165 out the end with just a little early morning side wind on Sunday.
Hope this helps.
JimL
