Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Bonneville Salt Flats Discussion
Bonneville General Chat
(Moderator:
Motorcycle Tire Size
« previous
next »
Pages: [
1
Go Down
Author
Topic: Motorcycle Tire Size (Read 2074 times)
mbuk
on:
October 15, 2013, 01:24:17 PM »
Building a Kawasaki KR1S (250 production) for Bonneville and i am having trouble getting the original tyre size in V rating which is 140/60/18, but i can get 140/70/18. Will the higher profile tire be good or bad or not make much differance?.
140/60-18 140/70-18 Difference
Diameter inches (mm) 24.61 (625.2) 25.72 (653.2) 1.1 (28) 4.5%
Width inches (mm) 5.51 (140) 5.51 (140) 0 (0) 0%
Circum. inches (mm) 77.33 (1964.12) 80.79 (2052.09) 3.46 (87.96) 4.5%
Sidewall Height inches (mm) 3.31 (84) 3.86 (98) 0.55 (14) 16.7%
Revolutions per mile (km) 819.37 (509.13) 784.25 (487.31) -35.12 (-21.82) -4.3%
Thanks
Andrew Lewis
sabat
Re: Motorcycle Tire Size
Reply #1 on:
October 15, 2013, 01:45:11 PM »
Hard to know exactly, but I would guess it won't make much difference, the speed rating is certainly more important in this case. Be sure to include an accurate circumference measure in your gearing calculation. good luck, Dean
donpearsall
Reply #2 on:
October 15, 2013, 02:19:01 PM »
Which Bonneville are you attending? Speedweek? BUB?
If BUB I asked the same question of Drew, the head AMA/FIM inspector and was told that with a production bike, it is allowed to change tire size if it is required to meet the speed requirements.
mbuk
Reply #3 on:
October 15, 2013, 03:01:08 PM »
Hi, i will be attending Speedweek. i don't think there's an tech issue. It's more a performance question.
Andrew
JonAmo
Reply #4 on:
October 15, 2013, 07:28:03 PM »
Well I guess if you use the 140/60/18 "V" you can't race.... Use the 140/70/18 and in this case it doesn't matter what it does, because you now can race... Doesn't seem like too much of an decision to me?
edinlr
Reply #5 on:
October 24, 2013, 11:09:18 PM »
The 70 series tire should be slightly taller than the 60 series, so it will raise your gearing slightly (lower numerically). I have found there is often as much as a half inch height difference between the same size tires, but it is probably less than a one tooth change on your rear sprocket. Enjoy the safety of your new tire.
Pages: [
1
Go Up
« previous
next »
Landracing Forum
(Moderator:
