So someone on a bike losses part of a fender and never notifies anyone about the missing item. Seems I recall during the driver meeting this was talked about. Calling your experience Lame course safety is nonsense. The Lame part is the individual who lost the part and didn't think it was of any safety concern to stop the runs until the part was found.
I agree ........ you're spot on regarding the
source of the issue. Even a hint of dropping a part on the big-end of a mile track
should be enough to set off mental alarms in any reasonable individual and generate concern for the well being of fellow competitors. Not initiating the proper actions immediately after having done so is clearly the concern at this point.
Since "we" can't/don't explore the ability and/or knowledge of the competitors prior to their involvement I'm putting it down to inadequate pre-race briefing. While this experience leaves me with some doubts in this regard, I went into Wilmington (and Maxton) with a level of confidence that the organization was well and truly concerned with (physical) track safety and that my back was covered. True it may be that "they"
are concerned, the actual conditions on the ground leave something to be desired.
One can insert a lot of "ifs" and "may-bes" but bottom line is there was a big ole ugly chunk of motorcycle lying out in plain sight on that course when I got waved off. Perhaps that is not so much of a concern for car-guys, but it's a big deal for scoot riders.
Point is there should be way better (more focused and comprehensive) pre-run briefings for us end users coupled (apparently) with better course scanning during/between runs.
Yeah, yeah, I know the argument can be made for "hundreds of runs without incident", etc., etc., but that success rate merely meets the base standard(s) of course safety .......... it's
this fail-rate that results in those "unfortunate" fatalities. And make no mistake, this speaks to a failure in a critical component of event safety.
I'm not all that bent about the guy dropping the part, nor not reacting in what should be considered the proper manner ........ dealing with that is up to the organization.
Seeing the incident result in change in how the organization educates competitors (learning from mistakes) and re-emphasizes the critical course scanning
is a worthy goal though ......... and in the interim making folks aware that they could be faced with a similar issue can't hurt either.
My chat with Keith at the conclusion of this event certainly did not inspire confidence.
Gotta go ride my motersikel now .......
