Author Topic: Solo to Sidecar by STD  (Read 133029 times)
Offline Koncretekid
Re: Solo to Sidecar by STD
« Reply #255 on: January 19, 2015, 07:07:19 PM »
Congratulations, Brian (and team) for a job well done.  I hope to see you guys back again this year.
Offline generatorshovel
    • http://www.dlra.org.au/forum/viewtopic.php?t=556
« Reply #256 on: January 19, 2015, 08:04:00 PM »
Love the bike, sidecars are one of my favorite road racers to watch!  We ran a header tank on our cross country bike years ago because of the fuel pump pressure problem. As you have the pump, battery, and switches already, perhaps you could add a small (1 pint or so) header tank as high above the carb as needed and use a carb needle and float shut off to keep from over filling the header tank. Should be easy enough to get a float shut off from an old car carb someplace. The small displacement records require just as much (maybe more so) work and thought to get as the larger ones.  :-D
Matt Guzzetta
My solution to the carb not handling fuel pressure very well,,,
I am enjoying your build Brian , thanks for sharing, :-D
Tiny (in OZ)
Offline Bruin
  • Just makin doo.
« Reply #257 on: January 21, 2015, 12:09:07 PM »
Thanks guys, good fuel suggestions. A header tank is a good solution. I'm mulling over my options during the winter with a preference for the most simple solution.
STD; Speed Team Doo
'82 Honda 500 APS-AF
'70 Triumph 250 MPS-PG
'71 Triumph 250 APS-PF
'70 Triumph 250 M-PG
Offline Bruin
  • Just makin doo.
« Reply #258 on: March 14, 2015, 06:27:41 PM »
I cut a new foredeck for the sidehack. The wheel use to hang off the side, now it is incorporated into the deck for better streamlining. That also gives the rider a tad more elbow room. I made the kickstart trap door longer so it would also give access to the mounting bolts. I'm still playing with the fairing design but the deck is a good start.
STD; Speed Team Doo
Offline Bruin
  • Just makin doo.
« Reply #259 on: March 27, 2015, 11:09:01 AM »
I'm making a bullet nose fairing for the sidecar out of an old Weber grill bottom. Head high and shoulder wide it ought to fit the bill. Making do!
STD; Speed Team Doo
« Reply #260 on: March 28, 2015, 10:03:55 AM »
I suspect it depends on how big "bill" is  :-D  :cheers:
Offline Bruin
  • Just makin doo.
« Reply #261 on: March 30, 2015, 10:47:19 AM »
The BBQ Fairing is mounted and painted. There are about three different shades of red on the bike but from a distance, it will pass.
STD; Speed Team Doo
Offline bak189
« Reply #262 on: March 30, 2015, 11:08:44 AM »
Don't forget as per the rules, you need handholds for the passenger (can not use the sidecar mountings
Question authority.....always
Offline Bruin
  • Just makin doo.
« Reply #263 on: March 30, 2015, 11:24:56 AM »
There are two dedicated handholds, one in the nose and one on the side. Both are sturdy. Test riders seem to like holding onto the nose handle with both hands.
STD; Speed Team Doo
Offline Koncretekid
« Reply #264 on: March 30, 2015, 09:37:55 PM »
Bruin,
I don't see any post on which to place that stack of barbell weights anymore.  Does that mean what I think?
Offline bak189
« Reply #265 on: March 30, 2015, 10:00:50 PM »
Looking good........................
Offline Bruin
  • Just makin doo.
« Reply #266 on: March 30, 2015, 10:53:39 PM »
Tom, I have two co-pilots standing by. My personal belief is that a sidecar should carry a passenger. If nothing else I think riding with a buddy/girlfriend might up the fun quotient. But as the rules allow for a minimum weight of 132 lbs, I will have some dead weight standing by if I'm in record contention. Instead of a stack of weights, I'm building a streamlined coffin to carry them in.
STD; Speed Team Doo
Offline Koncretekid
« Reply #267 on: March 31, 2015, 08:16:18 PM »
Brian,
The way I read the rules, you shouldn't need any additional weight if carrying a passenger.  The rule reads as follows:
 "In lieu of a passenger, mount a minimum ballast or weight of 60kg (approx 132lbs) and secure it in the sidecar."
So if you can find an 88 lb passenger, you should be legal.
Offline Bruin
  • Just makin doo.
« Reply #268 on: April 01, 2015, 12:15:54 PM »
Tom, I agree with your rule interpretation. Running with a passenger is my preference for fun. But if for some reason they can't ride I will have weights standing by. My volunteers weigh a tad more than 132 so I do reserve the right to run with dead-weight if I'm a hair off a record and need to lighten up. But ideally I want to make a good run with my cohort.
STD; Speed Team Doo
Offline Koncretekid
« Reply #269 on: April 02, 2015, 08:41:53 PM »
I could suggest an 88 pounder (will maybe a bit more) who I think would love to be your monkey, but I may need her again to help out as my pit crew!
