Author Topic: What's allowed in Diesel Truck classes (injectables)?  (Read 96141 times)
Re: What's allowed in Diesel Truck classes (injectables)?
« Reply #15 on: June 05, 2014, 04:54:13 PM »
Someplace, soewhere -- either here or in the Rule Book -- this has been discussed.  I remember sealing water tanks (like gas tanks) and using unopened pure water containers, etc.  Search and you shall find.  (I don't know how.)
Offline 38flattie
« Reply #16 on: June 05, 2014, 04:55:15 PM »
Steve, I have a snow system I am not using. You are welcome to use it if you wish
http://youtu.be/89rVb497_4c
« Reply #17 on: June 17, 2014, 10:56:12 AM »
KAAZZOOWWWWW!  Thanks for the offer - I don't know how I overlooked your post for so long.
Sending a PM now.
« Reply #18 on: June 17, 2014, 11:29:28 AM »
I would consider plumbing additional water to the area of the head that has the pre-cups  much like the SBC guys do on spraying, no squirting a lot of additional water to the area between the side by side exhaust valves.
« Reply #19 on: June 17, 2014, 11:59:45 AM »
I'm going to have to let this soak into my brain for a bit, then take a look at a spare cylinder head to see just what is possible.
« Reply #20 on: June 17, 2014, 12:23:32 PM »
Email sent.
« Reply #21 on: June 17, 2014, 12:30:54 PM »
PM sent
« Reply #22 on: June 18, 2014, 10:16:46 AM »
Valve Spring Oilers, spraying oil on the valve springs and the valve stems will also remove a ton of heat especially the exhaust.  It is possible to cool as much with oil as one can with air and water.
