Author Topic: Dodge Dakota C/BMMP  (Read 109388 times)
Offline Ron Gibson
Re: Dodge Dakota C/BMMP
« Reply #165 on: July 07, 2016, 06:29:20 PM »
Keep in mind that changing wheel or tire size will change the amount of scrub radius. The standard 28-29 model A axle is engineered for a 21" wheel, my tires are only 22" in diameter. Using the same backspace as stock with 15" wheels and small tires, the scrub radius would be way out of whack compared to stock. Set up with tires you intend to run.
YMMV
Ron
« Reply #166 on: July 07, 2016, 10:25:50 PM »
There is a reason most roadster guys try to never turn the steering wheel---it will "weigh jack" the drive wheels if you have to turn the steering wheel
Offline Brickster
« Reply #167 on: July 10, 2016, 03:47:09 PM »
A friend asked me what I had left to do so while sitting by the truck I started to list off what was left and it seems the more I do the more I realize I have left to do. One project reveals another. I think it's time for me to do an actual list to help me keep focused. I need to just keep nibbling away at it but I'll give credit to anyone who successfully builds and races anything. It's really a huge undertaking.
1995 dodge Dakota, C/BMMP
« Reply #168 on: July 10, 2016, 04:18:04 PM »
What a great way to get me to put links to these "What you need to know and do for Bville" lists:
http://www.landracing.com/index.php/component/content/article?id=78
Also see:
http://www.landracing.com/faq/checklist.htm
Not specifically on-point about your needed list -- but still, lotsa good stuff all of us need to know.  See you on the salt.
Offline Brickster
« Reply #170 on: February 19, 2017, 06:19:03 PM »
For whatever reason the links for the pics don't show the pics unless you click on them. Once your there feel free to look at the other pics.
Brick
« Reply #171 on: February 19, 2017, 09:02:48 PM »
Great progress. Nice fab work.
Offline Brickster
« Reply #172 on: April 08, 2017, 06:05:26 PM »
When I got this turbo it had a v-band on it. The one I got to join to it was different. So I had to mill the original
I scuffed down the pipe when I was done and all it did was highlight the inconsistency of my welding.
« Reply #173 on: April 08, 2017, 07:38:50 PM »
Is that a blow off valve you have installed on the manifold?  sure looks nice :cheers: :cheers: :cheers:
Offline Brickster
« Reply #174 on: April 08, 2017, 07:47:39 PM »
The BOV is just sitting on a rag in the last pic. I do have a large pressure gauge in the manifold facing forward. Thought it would look cool from the dyno control room to watch the manifold pressure during the test.
« Reply #175 on: April 08, 2017, 08:45:35 PM »
Way cool  ---or maybe a GoPro watching it on a run  :-D
Offline ///Ryan
« Reply #176 on: December 27, 2017, 06:02:23 PM »
This has been a great build to read through.  Hope you are still making progress.  I too am working on my first build.
Offline Brickster
« Reply #177 on: December 31, 2017, 01:44:15 AM »
Yup, still working away on it. Today I made some more progress on the intercooler. My hopes are to have the engine on the dyno in January
Offline Brickster
« Reply #178 on: February 18, 2018, 12:05:59 PM »
I finally got the engine, exhaust, cooling system, intercooler and fuel tank done. Removed it all from the truck and it’s now in the dyno room. Tuning and testing to happen in the next few weeks.
Offline Dakzila
  • 1956 Triumph cub
« Reply #179 on: March 02, 2018, 03:36:06 PM »
Nice project. Glad to see there are some more Vegas folks headed towards the "dirt and the salt".  Good luck and take care!
