Author Topic: Dodge Dakota C/BMMP  (Read 109908 times)
Offline redhotracing
Re: Dodge Dakota C/BMMP
« Reply #120 on: April 03, 2015, 10:19:49 PM »
What size/brand/AR is that? The first time I saw our 88mm Bullseye, I was blown away. Huge!
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Offline Brickster
« Reply #121 on: April 03, 2015, 10:40:10 PM »
It's a 94 mm Garrett. I've got two main guys collaborating on my engine build, Gil Neverez is the tuner and he picked and secured the turbo. He's asked me to keep some of the specs to myself, because he asked that's what I will do.
1995 dodge Dakota, C/BMMP
Offline Brickster
« Reply #122 on: April 08, 2015, 08:46:09 PM »
Got the front suspension located in the chassis. I've got to get the engine in place just so I can see if putting the monster turbo anywhere in the engine compartment.
I'm running out of room in a truck. How do the streamliner guys do it?
Brick
« Reply #123 on: April 09, 2015, 07:47:57 AM »
Streamliners are a true practice in packaging! As for running out of room, we had that issue in the Camaro, too, as I'm sure many people have. Relocating all the moveable stuff (water/IC/fuel/oil tanks) to the bed will surely help in more ways than one. Even the turbo itself, if you figure out an oiling solution...
Offline Brickster
« Reply #124 on: June 18, 2015, 01:40:50 AM »
Progress is slow but I've been moving ahead with some tin work.
Offline MattGuzzetta
« Reply #125 on: June 18, 2015, 05:19:27 PM »
Wow, not only a nice build, but great looking sheet metal fabbing. Nice project, keep the pics coming for us who love hanging out! :-D
Matt Guzzetta
Offline Brickster
« Reply #126 on: July 17, 2015, 02:12:35 AM »
Cams here, hope to see some progress on the short block by the end of the weekend
Offline Brickster
« Reply #127 on: October 18, 2015, 12:25:29 PM »
The engine is still moving ahead as time allows. Rods getting final cleaning before being assembled with the pistons and rings.
Don't have any pics of the rings being fit but they are gap-less and I was told it is a much longer process to fit them than a standard set of rings
After a lot of measuring a second set of main bearings were purchased that were under sized a bit to get the clearance Dan was after. Here is the crank just after it was set in hopefully for the last time.
Rods are getting torqued until the rod bolts stretch a specified amount.
So far the rotating assembly has been completed
« Reply #128 on: October 18, 2015, 02:31:52 PM »
Very nice work!
« Reply #129 on: October 20, 2015, 01:28:31 AM »
Brick
They don't, it does them!!!!. :-D :-D :-D
Truck's looking good Brick. :cheers:
Offline Brickster
« Reply #130 on: October 21, 2015, 01:43:17 AM »
Finishing up the short block
Adding all the Dailey Engineering dry sump goodies
Since the short block is about done its time to start on the heads. Hope they won't be too expensive.
« Reply #131 on: October 21, 2015, 01:47:09 AM »
How good is that ATI damper?????
Offline Brickster
« Reply #132 on: October 21, 2015, 01:58:15 AM »
The dampener was packaged with the dry sump stuff. Is there something about it I should know?
Offline Brickster
« Reply #133 on: January 24, 2016, 11:51:51 PM »
Valves arrived
Stock rockers get upgraded shafts and bearings
Wanted to get rid of the script
Finished most of the floor and firewall
Set hot fill rod on my finger
Modified the stock column
Pedal and MC with a balance bar
Needed to make the hub surface of the rotor match the wheel mounting surface
Front brakes, bearings, steering arms, studs all done
Starting on the pipes soon.
« Reply #134 on: January 25, 2016, 12:14:16 PM »
Fantastic progress on a great build!  I've always had a soft spot in my heart for that generation of Dakota, as well.  I bought a brand new, black, 2WD extended cab in 1992... wish I would have never let it go.
