Author Topic: Springfield Flyer.  (Read 1452763 times)
Re: Springfield Flyer.
« Reply #2640 on: September 21, 2016, 11:56:29 AM »
I want something that looks good and won't interfere with sizing.
The guy at TD says I won't have problems with my bearing clearances etc.
Thanks for the advice. The Nickel thing will take forever. The only guy I trust will
keep me waiting longer than I did for the helmet (9 months).
Some pics of my tandem steer units. All fine but I need to make a 1,5mm spacer plate for the upright.
« Reply #2641 on: September 21, 2016, 11:57:43 AM »
2 more pics of the same component.
« Reply #2642 on: September 21, 2016, 12:02:44 PM »
Mike,
The real advantage of electroless nickle is that it is not porous, like chrome, and therefore really provides protection against corrosion. In the off shore industry they require electroless nickle for plating of steel hydraulic manifolds that are exposed to sea water, it's that or stainless steel and machining a 2ft x 3ft blocks into a 5000 psi manifold is almost impossible with stainless and just the block is expensive if you can find one.
Offline rgdavid
    • fancy metalwork
« Reply #2643 on: September 21, 2016, 05:00:19 PM »
Would plating give hydrogen embrittlement problems to these lovely parts ?
« Reply #2644 on: September 21, 2016, 06:21:06 PM »
Your king pin is it in bearings or bushings?
What carries the load?
Without KPI did you get zero scrub with the wheel offset?
« Reply #2645 on: September 21, 2016, 07:25:30 PM »
No, electroless nickel plating does not do that.
« Reply #2646 on: September 21, 2016, 11:10:45 PM »
Bearings. In the second set of pics you'll see the housing has 5 threaded holes. It can be adjusted off the centre 16mm bolt.
Sid, you always give me sleepless nights. :cry:
« Reply #2647 on: September 21, 2016, 11:19:27 PM »
Sleepless NIGHTS----LOL
« Reply #2648 on: September 21, 2016, 11:26:50 PM »
Sparky, Sid's a tough guy.
The dude's from New Zealand!!!!!.
Any South African will tell you about those Kiwis.
We respect them big time. :cheers: :cheers:
« Reply #2649 on: September 22, 2016, 01:54:07 AM »
It's all constructive Mike, don't wanna see y'all hurt yerself Mate! :mrgreen:
You're going to be putting a lot of load on those end bolts there, keep an eye on them.
Good night Johnboy.
« Reply #2650 on: September 23, 2016, 03:03:26 AM »
I've always taken your advice and have huge respect for you friend.
I'll email you pics of all the components fitted in stages so you can tell me what you think.
Thanks Sid. :cheers: :cheers: :cheers:
Offline floydjer
« Reply #2651 on: September 23, 2016, 08:59:56 AM »
H-e double tooth picks with the steering...let`s see more pics of that way cool vise
« Reply #2652 on: September 23, 2016, 11:37:17 AM »
The Triton is made on OZ. When I first got it I hated it because we couldn't figure how it worked. Now
I use it all day for holding stuff I want to cut or weld.
Big vise is out back but once I move my friend's Lancia I'll bring the table inside. :cheers:
Offline Buickguy3
« Reply #2653 on: September 23, 2016, 02:19:27 PM »
    Here it is.   https://www.youtube.com/watch?v=WWWODa1JLAM
  I like it.
                   [America]
« Reply #2654 on: September 24, 2016, 04:26:47 AM »
Thanks Doug, that machine is similar. :cheers: :cheers: :cheers:
Sid wanted to know what I had done with my front hubs.
The outer housing was machined from EN8 to suit tapered bearings
with a 1" ID. The bearings have built in dust covers. They rest on an EN19 shaft
that's threaded with a M16x2mm tap to a depth of 30mm.
The top and bottom plates are 10mm thick with a 6mm recess where the shaft
seats.
