Author Topic: FUEL INJECTION AND BLOWER PARTS  (Read 2058 times)
Offline lsr48
« on: September 03, 2013, 07:55:07 PM »
FOR SALE
RIMS AND TIRES:  ( 1) 2 Steel Rims 18x5½ Bore 3.125 $200.00  ( 2) 4 Steel rims 16x4, 5/8”lug bolts, 5 on 5½” and 5 on 5”, bore 3.075” $250.00  (3) 2 Steel rims 15x6 ½’ lugs 5 on 5 ½” bore 2.900” $80.00   (4)   2 MT 24.5x7.50-16 tires mounted (1 time) for mock up. These tires are about 10 years old. Sell will be on contingent upon your inspection and cash offer. Note (1) tire shows a small area (side wall) where the rubber is starting to separate.  (5)  2 MT Bonneville National Tires 27.5x8-15 with center line rims. 5 on 5 ½” and 5 on 5” 5/8 lugs, bore 3.550”. Tires and rims would make good mock up or display $250.00
GOODYEAR FRONT RUNNERS:  (1) 1 D3703 26x4.5-15”, (2) 2 D3702 24.0x4.5-15”, (3) 2 D2031 28.0x4.5-15”, (4) 2 D2030 26.0x4.5-15”, (5) Goodyear Flight Eagle Aircraft tire 18x4.25-10, 210 MPH rating. All tires are good for mock up or display. Make offer.
FORD 9” THIRD MEMBERS: (1) 2.47 ring and pinion $100, (2) 3.0 ring and pinion $100.00, (3) 2.47 third member complete 31 spline with a steel coupler 20 spline N-Case $600.00, (4) 2.75 third member complete 31 spline with steel coupler 20 spline N-Case with pinion support $650.00, (5) 31-24 spline axle overall length 30.375” $50.00, (6) Mark William solid driveshaft 32 spline 38” long with 4 coupler lock rings (aluminum) $200.00
NASCAR PARTS: (1) 2 Pair of front hubs 5 on 5” $200.00, (2) 1 Pair of front spindles and hubs 5 on 5” $150.00, (3) 1 Pair of rear hubs and hats $50.00, (4) 1 new snout spindle $45.00, (5) 2 new snout L and R rear with nuts and locks $80.00
DISC BRAKES: (1) Wilwood Disc Brake Kit #140-0261-B Big bearing Ford rear axle solid rotor type 2.36 offset caliper billets, rotors , and hats 5 on 4 ¾” $450.00, (2) Aerospace Components front disc kit caliper billets, rotors, and hats 5 on 4 ¾” $450.00
Misc.:  (1) Patterson Enterprises dry sump tank 5” dia. X 15” long $125.00, (2) Alum. Tank 5” dia. X11 ½” long $50.00, (3) Stock Car Products 4 stage dry sump pump $550.00, (4) KB Pan Dooley Enterprises $125.00, (5) Pair Ford front spindle 1953-54 $75.00, (6) 2 System One Oil Filters and remote mount. With some fittings $100.00 each, (7) Dual Oil filter mount. $10.00, (8) Airheart Master cylinder $50.00, (9) Titon Master Cylinder $50.00, (10) CNC Master cylinder $30.00, (11) Cagle regulator $10.00, Summit SUM-G3120 dual feed $25.00, (12) P S Mack Prod. Rack and pinion $125.00, (13) 2 Afco Front Springs PN#103-21-1200 5 ½” x 9 ½” $60.00, (14) 2 Carrera Shocks PN#6CS900 coil spring 2 ½” ID 10” free length 900 LB rate $175.00, (15) C4 Corvette front suspension with rack and pinion $225.00.
FUEL INJECTION AND BLOWER PARTS: (1) Fuel shutoff valve $75.00, (2) High-speed assembly and check valve $50.00, (3) Barrel valve and check valve $150.00, (4) Alum storage holder for 40 bypass pills with 26 pills 30-160 $50.00, (5) Full distribution block (hat) $34.00, (6) Jet storage holder $18.00, (7) 8 nozzle body $40.00, (8) 3 Misc. pulley.
GAERTE ENGINE: Gaerte/Bodeck midget engine with -11 head $5000.00
BBC PARTS: (1) 4 BOLT MAIN TALL DECK 427 BLOCK 473478 (T0307XXY) $500.00, (2) 427 Steel Crankshaft #6223 $500.00, (3) 454 Crankshaft N3530339 $150.00, (4) 454 Heads 353049 & 336781 113cc open chamber, (5) Weiand Team G Intake manifold $150.00, (6) 1150 CFM gas Holley-Dominator $500.00, (6) Brodix valve covers $150.00, (7) Summit front cover, (8) MSD ignition 6AL with Mallory 9000 unilite coil and wires $200.00, (9) Comp Cam 11-220-4 lifters and pushrods, (10)  Water Pump, (11) 2 BBC Pans, (12) Pulleys and brackets.
Mike Wesche 406-360-8870 All parts will be at the World of Speed and El Mirage (September)
« Last Edit: September 08, 2013, 12:25:16 AM by SPARKY »
Offline Bob Drury
Re: FUEL INJECTION AND BLOWER PARTS
« Reply #1 on: September 07, 2013, 09:24:48 PM »
  In regard to Mike Wesche's above add, his correct phone number is (406) 360-8870.
Bob Drury
