Author Topic: Off the Shelf Front Spindle and Hub  (Read 14440 times)
Offline Richard 2
  • 2 Richards Racing
Re: Off the Shelf Front Spindle and Hub
« Reply #15 on: September 04, 2013, 01:19:23 PM »
Thanks Sid
4 cylinder Esslinger
Could of had a V8
Offline TheSteelMan23
« Reply #16 on: September 04, 2013, 01:23:40 PM »
Sid can you explain a little bit why you decided to use the arms and suspension on the front of Betsy vs. a solid mounted front end and just letting the tires absorb the shock. Would you still recommend using a suspension front vs a solid?
Sparky can you please explain the "walking beam" to me.
I have two speeds... Fast, and "What the hell was that!"
« Reply #17 on: September 04, 2013, 02:39:21 PM »
Due to tire size difference between the front & rear of the liner, the tire crowth will load the leading front tire more than the trailing tire without suspension. I believe the 2nd liner to turn up with a tandem front end was Roy Fjastad in the mid 90's. That was rigid & seemd to work. I don't know if they changed it later or not.
The walking beam system was pioneered by Hendrickson for semi trucks & trailers & still in use today.
That would be a lot simpler system to build. Basically a trailing or leading arm with both wheels mounted to it.
« Reply #18 on: September 04, 2013, 02:50:45 PM »
Sid Explained it better than I could and he is correct about frt and rear they are also slightly offset 1/8" to stop any Motorcycle tricycle discussions
---Higginbotham only runs one set of tires--MT 30" rears  and 24"s on the frt.-He has to put shocks on it because it did piviots between the tires I have driven it after it was sorted out  but it had the issues Sid talks about and wanted to pull---it did not have zero scrub radius to start with.  It would be fairly easy to make this system Frt. wheel drive also using 4 wheel drive strg. knuckles
Offline Richard 2
  • 2 Richards Racing
« Reply #19 on: September 04, 2013, 07:44:39 PM »
Sid, Sparky, Would you have to hinge the walking beam on one end to keep it from wanting to hop, rather than in the middle like a truck. (shocks would be needed either way)
Sparky could you explain;  "It would be fairly easy to make this system Frt. wheel drive also using 4 wheel drive strg. knuckles."
Thanks Richard
Could of had a V8
« Reply #20 on: September 04, 2013, 08:38:29 PM »
In theory would four of the same size tires negate the need for suspension to compensate for uneven tire growth?
« Reply #21 on: September 04, 2013, 09:05:42 PM »
it would not be a walking beam if it were hinged on one end.
Build it like Sid talked about but use 4x4  axle shafts ends and tubes  no diffrential  h
use blower drive belts to drive them from a jackshaft between the tires  from a diff behind the rear tire.  4 belts all told
Offline Richard 2
  • 2 Richards Racing
« Reply #22 on: September 04, 2013, 09:20:13 PM »
Thanks Sparky      I guess if you hinged the beam on one end it would be like a swing arm on a truck air bag setup. Would probably need two arms one for each wheel on a streamliner.
Could of had a V8
« Reply #23 on: September 04, 2013, 09:57:51 PM »
Jason, in theory that would solve the issue.
In the design stages of my "nightmare on any street" I actually looked into the idea of a driven tandem front end to narrow the front up but that gave me the issue of having to see over that whole mess & that just increased the frontal area plus it would up the amount of custom crap I would need to have built. Not on my budget!
With the 30" Mickey's side by side, my line of sight is only 21" agl. & the top of the liner only 31.
Richard, I think a single trailing arm with both wheels on it swung from the front would work.
« Reply #24 on: September 05, 2013, 12:18:45 PM »
Sid I have been wondering how your project was coming along, I was hoping to see pictures of it in the 2013 SW thread. Your frustrations with getting things custom built is exactly why I am going to do it with off the shelf stuff if I can't make it myself, or I'm not going to do it. Like you I am very budget conscious
« Reply #25 on: September 05, 2013, 03:53:52 PM »
Well, you'll be ahead of me Jason. I can't even afford a budget but it is very doable with lunch money.
Offline Podunk
« Reply #26 on: September 06, 2013, 08:21:02 PM »
Jason,
Call me 219-988-2775 weekdays 8-5 central. I do custom machining at a reasonable rate.
Terry
« Reply #27 on: September 10, 2013, 09:56:18 AM »
Thanks Podunk I will keep your number on hand. I am still going to try to do stuff off the shelf, but if I need anything done I will get in touch with you. I have seen pics of some of the work you have done and it looks like great stuff. Thanks
