Sid, would you please explain what you mean by; "but we loaded it into the bottom stops to prevent rise"
Thanks Richard
Sure Richard.
We had adjustable stops under the axles to be able to set the load on each front wheel to counteract the tire growth difference between the rear (drive) tires & the steer tires. Steer tires were 24" Firestones & on the rear we ran everything from 28" 700x18 Firestones all the way up to some 35" monsters from Art Arfons.
The axles were 10" long & swung from opposite sides of the chassis with torsion bars. That in it's self would have induced radical camber change without the stops plus Al & I both believe there is no desire to have an LSR vehicle unload the suspension.
We had no difference on the turning circle between the front & rear & ran the same two tires for years.
The front tires were not actually in line with each other, they were staggered. The rear one was swung from the right with the wheel on the left & the front one was opposite.
Betsy always ran like she was on rails other than one time Al ran over some space junk & cut a front tire.
