NASCAR Parts
2 Pair of front hubs 5 on 5” $200.00
1 Pair of front spindles and hubs 5 on 5” $150.00
1 Pair of rear hubs and hats $50.00
1 new snout spindle $45.00
2 new snout L and R rear with nuts and locks $80.00
DISC BRAKES
Wilwood Disc Brake Kit #140-0261-B Big bearing Ford rear axle solid rotor type 2.36 offset caliper billets, rotors , and hats 5 on 4 ¾” $450.00
Aerospace Components front disc kit caliper billets, rotors, and hats 5 on 4 ¾” $450.00
Misc.
Patterson Enterprises dry sump tank 5” dia. X 15” long $125.00
Alum. Tank 5” dia. X11 ½” long $50.00
Stock Car Products dry sump pump4 stage $550.00
KB Pan Dooley Enterprises $125.00
Pair Ford front spindle 1953-54 $75.00
2 System One Oil Filters and remote mount. With some fitting $100.00 each
Dual Oil filter mount. $10.00
Airheart Master cylinder $50.00, Titon Master Cylinder $50.00, CNC Master cylinder $30.00
Cagle regulator $10.00, Summit SUM-G3120 dual feed $25.00
P S Mack Prod. Rack and pinion $125.00
2 Afco Front Springs PN#103-21-1200 5 ½” x 9 ½” $60.00
2 Carrera Shocks PN#6CS900 coil spring 2 ½” ID 10” free length 900 LB rate $175.00
C4 Corvette front suspension with rack and pinion $225.00
All parts will be at the World of Speed and El Mirage (September)
Mike Wesche
mttoolbox@gmail.com
406-360-8870
